Pocket GPS World :: View topic - Navman Setup error for SmartST for iCN530
ukcommando41
PostPosted: Tue Jun 27, 2006 1:38 pm    Post subject: Navman Setup error for SmartST for iCN530 Reply with quote
hi all. i've been trying to setup SmartST for iCN530 from the dvd that came in the box but keep getting the error message -5009:0x8002802b. i've tried it with all other applications closed; not/connected to the net but still no joy. why?
smoose
PostPosted: Tue Jun 27, 2006 2:27 pm    Post subject: Reply with quote
Do you have admin rights to install new software. If not this may be the issue.
ukcommando41
PostPosted: Tue Jun 27, 2006 4:39 pm    Post subject: Navman Setup error for SmartST for iCN530 Reply with quote
hi smoose. i do have admin rights. i now find that when i try to run "E:\Setup SmartST for iCN530.exe" from the disc i'm told that the system could not find the file, which is read-only
Tim Buxton
PostPosted: Tue Jun 27, 2006 5:51 pm    Post subject: Reply with quote
Try running Install.exe from the same CD.
Tim
nortonbeak
PostPosted: Tue Jun 27, 2006 9:40 pm    Post subject: Re: Navman Setup error for SmartST for iCN530 Reply with quote
[quote="ukcommando41"]keep getting the error message -5009:0x8002802b. quote]
A Google search suggests that the error is connected with Installshield.
May be a dodgy disc.
Navman ICN 520
512 Mb Cygnet SD card
Smart ST 2005 + SP 1
smoose
PostPosted: Tue Jun 27, 2006 10:30 pm    Post subject: Reply with quote
Only other suggestion would be, if you have the space on your hard disk try coping the contents of the cd to a new dir on the HD. Then try running the install from there.
Its worked when some of our customers have encountereed problems isntalling software
ukcommando41
PostPosted: Wed Jun 28, 2006 12:16 pm    Post subject: Reply with quote
You've got it nortonbeak.
The problem was with installshield.
Searching for the code -5009 (instead of the whole error message) took me to a forum which had someone else experiencing the same problem. It was resolved by renaming the isprobe.tbl file so that installshield would automatically install a new and functioning version of it when its was next run. The path to the file is: C:/program files/common files/installshield/professional/runtime/isprobe.tbl I renamed the file xisprobe.tbl
Thanks everybody for you help, it was much appreciated.
chris
22.064 (26 Jun 24)
