ukcommando41 Occasional Visitor
Posted: Tue Jun 27, 2006 1:38 pm Post subject: Navman Setup error for SmartST for iCN530 |
hi all. i've been trying to setup SmartST for iCN530 from the dvd that came in the box but keep getting the error message -5009:0x8002802b. i've tried it with all other applications closed; not/connected to the net but still no joy. why? |
smoose Occasional Visitor
Posted: Tue Jun 27, 2006 2:27 pm Post subject: |
Do you have admin rights to install new software. If not this may be the issue. |
Posted: Tue Jun 27, 2006 4:39 pm Post subject: Navman Setup error for SmartST for iCN530 |
hi smoose. i do have admin rights. i now find that when i try to run "E:\Setup SmartST for iCN530.exe" from the disc i'm told that the system could not find the file, which is read-only |
Posted: Tue Jun 27, 2006 5:51 pm Post subject: |
Try running Install.exe from the same CD. _________________ Tim |
nortonbeak Regular Visitor
Joined: Oct 08, 2005 Posts: 186 Location: North East, England
Posted: Tue Jun 27, 2006 9:40 pm Post subject: Re: Navman Setup error for SmartST for iCN530 |
[quote="ukcommando41"]keep getting the error message -5009:0x8002802b. quote]
A Google search suggests that the error is connected with Installshield.
May be a dodgy disc. _________________ Navman ICN 520
512 Mb Cygnet SD card
Smart ST 2005 + SP 1 |
Posted: Tue Jun 27, 2006 10:30 pm Post subject: |
Only other suggestion would be, if you have the space on your hard disk try coping the contents of the cd to a new dir on the HD. Then try running the install from there.
Its worked when some of our customers have encountereed problems isntalling software |
Posted: Wed Jun 28, 2006 12:16 pm Post subject: |
You've got it nortonbeak.
The problem was with installshield.
Searching for the code -5009 (instead of the whole error message) took me to a forum which had someone else experiencing the same problem. It was resolved by renaming the isprobe.tbl file so that installshield would automatically install a new and functioning version of it when its was next run. The path to the file is: C:/program files/common files/installshield/professional/runtime/isprobe.tbl I renamed the file xisprobe.tbl
Thanks everybody for you help, it was much appreciated.
chris |
