mark_shillam Occasional Visitor
Posted: Fri Dec 05, 2003 3:01 pm Post subject: TomTom GPS wireless - Bluetooth dead! |
Hi guyz ,
I have the following problem:
I have recently acquired a HP 1940 in bundle with
TomTom gps Bluetooth and all has worked fine for some day.
Without warning, then, the gps has stopped to communicate with the 1940, the intermittent blue lights no more,
it is only ignited for a fraction of second to the ignition, then the only light that remains ignited is the continuous green.
And the gps practically is invisibile, also to the Bluetooth port of my mobile. 8O
So:
- green light always on
- no blue light at all (not flashing nor always on)
and my HP 1940 won't see the GPS module at all.
Any suggestions? Is it definitively broken (I bought it ONE MONTH ago.. )? |
lbendlin Pocket GPS Staff
Posted: Fri Dec 05, 2003 4:29 pm Post subject: |
I think there have been threads around here on the forum about that (try a search) - have you already tried to drain the backup battery on the GPS receiver for a longer time?
Eventually your unit may just have died and you would need to send it to your vendor for a replacement. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Dave Frequent Visitor
Posted: Fri Dec 05, 2003 5:13 pm Post subject: |
Mark, sorry to say it's . You will need to return this to the retailer you purchased from or TomTom direct. There does seem to be some sort of issues in over charging or spiking, but we haven't been able to put our finger on which it is yet. |
Darren Frequent Visitor
Posted: Fri Dec 05, 2003 7:23 pm Post subject: |
Yes there does appear to be some issues with this device, mine expired in the very same way earlier this week. Gave it a charge and now all I get is the BT LED blinking once on power on and then just the right hand green LED. No BT communications.
I have tried draining the battery until it powers off and then leaving for 48hrs, after a subsequent full charge it was the same. I may try detaching the internal battery and leaving for a while longer to guarantee any remaining charge in the capacitors is discharged. _________________ Darren Griffin |
Posted: Tue Dec 09, 2003 11:40 am Post subject: Thanx guys |
.. thanx a lot for all your answers..
Darren how can I detach the battery from the receiver?
Shall I open it?
If I open the receiver, is the warranty still valid?
Thanx :-D |
Posted: Tue Dec 09, 2003 12:18 pm Post subject: |
You would invalidate the warranty by opening the case. If you're happy to try then simply remove the two screws on the bottom of the unit. The top cover lifts off (no clips to worry about) and underneath the receiver circuit board is the battery. It can be detatched by unclipping it's connector from the circuit board. _________________ Darren Griffin |
Posted: Tue Dec 09, 2003 6:15 pm Post subject: |
mmmmhhhhhh.....
I think I'll not open it... I think I'll let it 5 days off before recharging!
I don't want the warranty to be voidened.. 8O
What about your GPS module Darren?
Is it ok after battery removal?
Mark. |
ian Occasional Visitor
Posted: Thu Dec 18, 2003 10:29 am Post subject: I have exactly the same problem - TomTom Bluetooth |
Mark,
I have exactly the same symptons on my 6 day old TomTom Bluetooth GPS receiever.
It worked fine for 2 days and then no Bluetooth LED or communication....!!!
I have tried the battery discharge without success and now I am pursueing sending it back to Total PDA for replacement.
Needless to say I am not impressed...!!!
Have you got any update or sorted yours yet...???
Cheers,
Ian |
paulgps Occasional Visitor
Posted: Mon Dec 29, 2003 11:43 am Post subject: |
The Bluetooth on my TomTom BT GPS has also died. It happened on a trip from Liverpool to Cornwall (around 6 hours) with the unit permanently powered from the cigarette ligher, so Dave's comment about overcharging may well be correct. Has anyone successfully managed to fix the problem? Failing that, has anyone successfully managed to return the unit to TomTom and have it replaced? I've had the package for over two months, so I'm sure the retailer will tell me to deal direct with TomTom. Any advice with regard to the TomTom returns process would be very gratefully received.
Thanks. |
Posted: Mon Dec 29, 2003 11:49 am Post subject: |
Removing the battery made no difference to my defective unit. I now have my replacement installed in the cradle and permanently wired in to the 12v supply and so far it's been working for two weeks without a problem (fingers crossed ).
As for replacement, if purchased in the UK then your warranty is with the retailer, they are responsible for replacing it not TomTom so take it up with them. Read this DTi Guide before you speak to them and then If they try to wriggle out of it and tell you to contact TomTom remind them of the Sale of Goods Act _________________ Darren Griffin |
JJ28 Occasional Visitor
Joined: 12/08/2003 20:27:16 Posts: 31 Location: United Kingdom
Posted: Wed Jan 07, 2004 2:15 pm Post subject: And another |
Well my 6 month old TT Bluetooth has given up the ghost. No BT light and all charged, discharged etc.
So off to TT is goes.
Have to say that TT support were very good indeed.
Thanks |
redmax Occasional Visitor
Posted: Thu Jan 08, 2004 9:26 pm Post subject: |
Just like to say, as this is my first post, what an excellent site this is.
I have educated myself no end with the threads so keep up the good work.
Now...
I purchased my TT2 bluetooth & 2210 form Total PDA on 18th Dec 03.
I have probably used it for no more than a total of 7 days and it has gone belly up.
Just as above posts all I have is a permanent green light and no bt light.
If you switch it on there is a single flicker of the bt light but thats it.
To say I'm gutted would be an understatement
Question:
Has anyone successfully returned the unit under warranty and had an agreeable outcome. ie a new unit?
What about shipping costs?
Why should I pay to return it? - as a consumer have I any right to get reimbursed for any costs like postage & phone calls from total PDA.
I plan to call TPDA tomorrow so any advice would be appreciated.
TTFN |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Fri Jan 09, 2004 7:53 am Post subject: How did you power your Bluetooth? |
Out of interest how did you power your Bluetooth?
I was wondering if there was any commonalitiy between the way it is powered and the failures. I was wondering if the 12V to 5V regulator (LM2756T) in the cigar lighter lead might be the problem and surges in the car voltage supply may pass through it. Or is there any commonality in the car where a particular make has large spikes?
I use the 12V hard wired supply and the mains adaptor and rarely the cigar lighter lead and I have not had a problem. Both were used in Ford cars.
Around a year ago I saw a similar issue with a popular laser jammer in cars and the problems there were attributed to spikes on the car electrical system. A few people protected themselves by putting heavy suppression (capacitors) on the cigar lighter supply. |
Posted: Fri Jan 09, 2004 8:46 am Post subject: |
redmax wrote: | What about shipping costs?
I plan to call TPDA tomorrow so any advice would be appreciated. |
Under warranty you have the right to a replacement or exchange. AFAIK this doesn't include claiming for out of pocket expenses. Can you imagine it if you wanted to take it back to TomTom as they are the manufacturers, you decided to buy a plane ticket, fly over to Netherlands, stay a couple of nights in a hotel ? And wanted reimbursement for all of these costs ?
You can always see if the company is willing to pay a good will jesture for out of pocket expenses, but the company (e.g. TotalPDA) have two options available to them once you have returned the product.
1) write off the cost of the product which means they are completely out of pocket by not only the cost of the product to them, but the difference between the buy-in price they pay, and the amount they refund you.
2) to send the faulty unit back to TomTom, so they are actually incurring in most cases more charges than you due to international courier charges, and they won't get these reimbursed either in most cases!
So you could try to see if you'll get anything else back, some companies might give you a free or cheap upgrade to another product if you would rather not have the same product as a replacement, and do this as a good will payment, but most will only provide a like for like replacement with no additional reimbursement. |
Posted: Fri Jan 09, 2004 9:34 am Post subject: Warranty Returns |
Certainly in the first month of a products life you have the right to return a faulty product at the suppliers expense. The supplier has the right to arrange the return method. Under any other legislative rights for faulty goods the supplier also has the burden of the return.
However a guarantee is an offer made the manufacturer over and above any legislative requirements and they can set any legal terms and conditions they wish. You do have the legal right to expect a reasonable period of service from a product.
Most reasonable suppliers guarantees will expect you to pay the return of the item to them and they pay the cost of shipping the repair/replacement to you. Some make you pay both and some pay for both.
I decided to go for the HP Care Pack for my PDA as it offers a next day exchange replacement for 3 years, they pay all shipping costs, for about 12% of the cost of the PDA. I would have difficulties not having my PDA for a week or more. |
