Pocket GPS World :: View topic - POI Downloads for Navman ICN 530
chopper7
PostPosted: Mon Jun 26, 2006 10:10 pm    Post subject: Reply with quote
ok i give up, spent all afternoon trying to download poi's from the blueyonder site saved them clicked on poi editor opended files clicked on the poi i want and all i get is unknown format.
keith
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:12 pm    Post subject: Reply with quote
Have you extracted the files after saving them?
Tim
chopper7
PostPosted: Mon Jun 26, 2006 10:17 pm    Post subject: Reply with quote
no one said anything about extracting them!
keith
stephenchappell
PostPosted: Mon Jun 26, 2006 10:19 pm    Post subject: Reply with quote
Tim Buxton wrote:
Save the Postcodes and addresses in an Excel file (or .asc, .csv, etc.) and then import them into Autoroute. Save the file as an .axe file and then convert the .axe file to a Tomtom .asc file using Oldie's POIConverter. (A Google search will help, or click on Oldie's www button.) This .asc file will then import directly into the Navman POIEditor.
ok i have done this, i used my home address and saved it as a test, and converted it to ascii and got it to go into my pois on my phone, and ermmm navigated to it even though i am at home and it said the poi (my home address) was about 6 miles away :-( but on autoroute 2005 it was right on top of the route? any ideas, i dont fancy doing about 300 garden centres if they are not going to be even close
chopper7
PostPosted: Mon Jun 26, 2006 10:27 pm    Post subject: Reply with quote
right ive extracted them and got to the save device bit etc but only the top line was highlighted, do i ahve to add each and every line? of the excel file
keith
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:29 pm    Post subject: Reply with quote
keith
Mojo said
Just unzip the files
on page one, to which you replied
thanks, but im still struggling sob
So someone did actually say something about extracting them.
Tim
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:31 pm    Post subject: Reply with quote
keith
There is no Excel file. It is a .csv file and if you open it in Excel then you will corrupt it. You shouldn't have to add each and every line, the file should go in. Have you searched for any of your newly imported POIs?
Tim
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:33 pm    Post subject: Reply with quote
If you just put your full postcode into AR2005 into the 'Find' box, where does it show it?
Tim
chopper7
PostPosted: Mon Jun 26, 2006 10:39 pm    Post subject: Reply with quote
yahooooooooo tim is the greatest tim is the greatest! cheers dude it worked thank you
keith
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:42 pm    Post subject: Reply with quote
keith
I wouldn't go quite that far, but am glad (and relieved) that you are now up and running. 8)
Tim
stephenchappell
PostPosted: Mon Jun 26, 2006 10:49 pm    Post subject: Reply with quote
the post code is right on the nose (or door step) when i look at the pin on ar2005 it is exactly right, i have saved the file again and it still puts the location on navman 6 miles away?
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:53 pm    Post subject: Reply with quote
How strange. Occasionally one is a bit out, or can't be recognised by AR, but I can't think what's happening in your instance. I've made many files using this method and although I don't check every location, they are generally reasonably accurate of the few places I have checked.
Tim
Tim Buxton
PostPosted: Mon Jun 26, 2006 10:54 pm    Post subject: Reply with quote
When you've saved the file as an .asc, can you re-import it (the .asc) into Autoroute and see where the pushpin is?
Tim
chopper7
PostPosted: Mon Jun 26, 2006 11:00 pm    Post subject: Reply with quote
ok tim now u have solved that problem got another one for you and this is your challenge if you are prepared to accept it. how do i find out about low bridges and load them in as a warning as i have a motorhome and am rather attached to the roof bit. i have a icn530navman.
keith
stephenchappell
PostPosted: Mon Jun 26, 2006 11:09 pm    Post subject: Reply with quote
i have just re done the push pin in ar2005 and then saved as an ascii and converted it and inserted into my navman as before and guess what
its bang on this time? although it did say i was in the street behind mine but then i was stood in the back garden.
i will try a few garden centers in aa2005 tomorrow and see how it goes
thanks for the help :D
Page 2 of 3
22.094 (25 Sep 24)
