neilwalls Occasional Visitor
Posted: Mon Jun 26, 2006 9:20 pm Post subject: IrDA and card issue tomtom 3 |
Hi.. I have tomtom3 on my HP Jornada 520. It all works brilliantly apart from I can only install via Infrared! I have a card reader and a 256mb CF card, but when i install it on the card, TT does not see it!? Any ideas? Do i need to upgrade to 3.02 or 3.07? Which i have both of..
When i use TT to copy it to the card with card reader, it just makes a folder. When i do it via infra red it puts a cfg file on the pda root folder.
Thanks!
Neil :P |
alix776 Pocket GPS Moderator
Posted: Mon Jun 26, 2006 9:25 pm Post subject: |
which jornada do you have and can you not use the cradle _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Jun 26, 2006 9:28 pm Post subject: |
I got the PDA of family member, did not have a cradle, and I cant find the serial cable.. Its the 525 I think, and it is only serial I am led to beleive.. I have ordered new cables for it, but I am going away tomorrow and wanted to put whole GB map on, but will take many many hours via infrared. Frustrating as it only takes seconds with card reader.. |
Posted: Mon Jun 26, 2006 9:33 pm Post subject: |
itll be LONG night then _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Jun 26, 2006 9:35 pm Post subject: |
booo so why does tomtom setup give you an option of memeory card reader if it does not work! |
Posted: Mon Jun 26, 2006 9:49 pm Post subject: |
you can install the map via a card reader just install the app via irda or if you right click the set tt set exe and extract the files you shuld be able to get a the cab files copy these to the card and you sould then be able to install nav3 via the cf card just make them read only on the pc before copying them to the card _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Jun 26, 2006 9:57 pm Post subject: |
ive tried installing to pc then copying, and getting tt3 to install to cf card direct via reader.. both not recognised by tt3 when it runs.. |
Posted: Mon Jun 26, 2006 10:02 pm Post subject: |
have you tried installing direct from the cd _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Jun 26, 2006 10:06 pm Post subject: |
yes a 16mb chunk...works fine.. |
Posted: Mon Jun 26, 2006 10:07 pm Post subject: |
try doing a full country direct from the cd _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
