inviroman Occasional Visitor
Posted: Mon Jun 26, 2006 8:47 pm Post subject: icn 520 speed cams |
Hi all
This is my first post just got a icn 520 and have put the speed cams on it is there a way for it to display a warning of the speed cam on the full display instead of at the bottom and can anyone recommend a good full 7 digit post code download?
Thanks |
alix776 Pocket GPS Moderator
Posted: Mon Jun 26, 2006 8:52 pm Post subject: |
here the how to for the 5 navman icn
http://www.pocketgpsworld.com//uksafetycameras-navman.php _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Jun 26, 2006 8:59 pm Post subject: |
thanks for the reply but that is not what i asked i have already put the speed cams on the icn by following the instructions which work fine but i want to know if a large icon can be displayed on the full screen instead of the just the text line at the bottom |
Posted: Mon Jun 26, 2006 9:34 pm Post subject: |
No, it isn't possible. _________________ Tim |
Posted: Tue Jun 27, 2006 1:12 pm Post subject: |
cheers |
Posted: Tue Jun 27, 2006 10:35 pm Post subject: |
can you install a new sound for the camera poi so instead of the dong can you have a voice for moblie /gatso/specs etc
also is it correct that you cant install the full speed cams list of 23 files so it shows the speed in the poi icn i have been told that you can have only 16 active poi's |
captureboy Regular Visitor
Posted: Thu Jun 29, 2006 6:59 pm Post subject: |
I was just about to post a question why I cant have more than 16 files in my POI. Thanks for the info, I'll have to download the speed cameras as files by camera type rather than by speeds. |
mags Lifetime Member
Posted: Sun Sep 03, 2006 12:30 am Post subject: voice over the dong |
I too would like to hear a vioce reminder that i am approaching a speed camara and not just a dong reminder
but from what I have read this is not possible |
BlueNev Occasional Visitor
Posted: Fri Sep 07, 2007 9:48 pm Post subject: Re: voice over the dong |
mags wrote: | I too would like to hear a vioce reminder that i am approaching a speed camara and not just a dong reminder
Me too. I have got hold of a voice "Warning Speed camera ahead" as a .WAV file, and am going through all the .WAV files in the Windows (CE) diretory of the Navman to no avail... I did here the voice at startup as startup.wav is now the voice... but can't find the "BELL" sounds to alter them.
I suspect they are part of the UKFEM.dat file?
Anyone solved this elsewhere? ... going to look now
BlueNev |
mostdom Pocket GPS Moderator
Joined: Jul 10, 2006 Posts: 1964 Location: Surrey, UK.
Posted: Sat Sep 08, 2007 8:11 am Post subject: |
For the icn5** I recall seeing a post which explains that the only possablity to change the sound is to directly manipulate the file on the device.
Read this
And this _________________ Dom
Navigon 7310/iPhone Navigon&Copilot |
Posted: Sat Sep 08, 2007 10:06 pm Post subject: |
icn520 (not tried on others)
Eventually found ... the answer, in the depths of those links, thanks
like many others I probably need to have things spelled out...
In MYPOI folder there are the SPEEDCAM .map .bm .chk files and the following .ini file... with an extra line added, soundfile=, for with a .wav file held in the same directory.
[SPEEDCAM]
active=1
distance=200
time=0
visualWarning=1
soundWarning=1
soundfile=camera.wav
tere is no need to alter the currmap.ini file
I am going to play with the time=0 setting to see what happens.
Will also test the soundfile in am.
I will also try to add a number to the voice. I have .wavs for 30, 40 , 50 and 100!!! |
