Pocket GPS World :: View topic - Unusual POI/Camera database Behaviour ?
wherethehellarewe
PostPosted: Mon Jun 19, 2006 6:46 pm    Post subject: Unusual POI/Camera database Behaviour ? Reply with quote
Hi All
I've recently installed MaFt's POI's and PGPSW camera data base and I'm using Ash10's application to modify my alerts. Both POI's and the data base are stored on my SD card and the whole thing is working as advertised. One thing that is puzzling me is that all the threads I have read state that when the POI's and camera database are saved to the same directory they should download at once, mine do not do this. I insert the SD card in the reader and I have to load both the POI's and the camera database separately although both files are contained in the same directory. Have I read all the other info incorrectly or have I done something wrong with downloading the POI's and camera database ? Both the POI's and the camera datbase are in a folder called 'Garmin POI and camera information'
Thanks in advance
Ignorance is no excuse !
PaulB2005
PostPosted: Mon Jun 19, 2006 8:06 pm    Post subject: Reply with quote
1) What hardware?
2)
This is for when you use the POILoader software.
wherethehellarewe
PostPosted: Mon Jun 19, 2006 9:36 pm    Post subject: Reply with quote
PaulB2005 wrote:
1) What hardware?
2)
1. Hardware Garmin i3, software release 3, audio 2.5
2. Yes, that's the point I was making, I thought the POI loader loaded everything that was in the directory but it's only loading either the POI's or the camera database, not both together.
wherethehellarewe
PostPosted: Mon Jun 19, 2006 9:37 pm    Post subject: Reply with quote
I don't appear to have an edit option, when I said software release 3 in the above post I meant firmware Rolling Eyes
PostPosted: Tue Jun 20, 2006 8:42 am    Post subject: Reply with quote
all thecsv files need to be in one single folder, not split into sub-folders. does this help? if not then please provide more info.
wherethehellarewe
PostPosted: Tue Jun 20, 2006 11:02 am    Post subject: Reply with quote
Well I followed the i3 guide for dummies http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=29719
These seem to be the relevant steps:
6) Next make & name a folder on your computer calling it Garmin I3 POI’s & Safety Camera Data or similar.
7) Download the latest POI’s to this folder.
http://www.MaFt.co.uk/garmin/download.htm
8) Download the latest Safety Camera Data to the same folder.
http://www.PocketGPSWorld.com/uksafetycameras.php
When I do steps 6 to 8 above I have an icon on my desktop called Garmin I3 POI’s & Safety Camera Data, when I double click that icon I get 2 separate folders showing, one with POI's the other with the camera data. Assuming I download the camera data second should I be downloading that to the POI's folder rather than Garmin I3 POI’s & Safety Camera Data folder ?
trevf
PostPosted: Tue Jun 20, 2006 11:58 am    Post subject: Reply with quote
Yep. All of the actual files need to be in the same folder.
Garmin i3
Firmware 3.4
PostPosted: Tue Jun 20, 2006 12:05 pm    Post subject: Reply with quote
remember that when you unzip the zip files (either speed cams or my poi's) it may actually be adding a sub-folder to the folder you are already in. just make sure all the files are in the same place and not in any other folder!
wherethehellarewe
PostPosted: Tue Jun 20, 2006 12:16 pm    Post subject: Reply with quote
:D
That's cracked it guys. Thanks for your help !
22.064 (26 Jun 24)
