Pocket GPS World :: View topic - Medion MDPPC250 Car charger question
skate2create
PostPosted: Mon Jun 19, 2006 4:14 pm    Post subject: Medion MDPPC250 Car charger question Reply with quote
Hi all, first post so be gentle! Smile
the car charger for the MDPPC250 sat nav, is the green light on the adapter meant to flash when it has power from the ciggy lighter or when it has a signal from the gps?
As I don't know if my charger is fubar'd or not Rolling Eyes
Thanks in advance.
Dan
dabut
PostPosted: Mon Jun 19, 2006 6:41 pm    Post subject: Re: Medion MDPPC250 Car charger question Reply with quote
Thanks in advance.
Dan
the green light is there to tell you that its receiving power from ciggy lighter.if it is flashing then there may be an intermittent fault
ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6
Border_Collie
PostPosted: Mon Jun 19, 2006 9:37 pm    Post subject: Reply with quote
First thing to do is push the connector in gently and give it a few twists left and right, could be dirt in the cigar lighter.
philip4242
PostPosted: Mon Jun 19, 2006 9:59 pm    Post subject: Reply with quote
'... the green light is there to tell you that its receiving power from ciggy lighter.if it is flashing then there may be an intermittent fault'
While it might possibly be that the OP's power adaptor is faulty (or not receiving power - I once had the fuse in the front part of the adaptor fail, for no reason I could see !), if I remember correctly, on my MDPPC250 setup, the green LED on the car power adaptor flashed for a short time every 1 second to show that data was being sent from the GPS receiver (whether the receiver was actually receiving a GPS signal or not).
The length of time it flashed for depended on which GPS 'sentences' were being sent that second, since some sentences are commonly sent every 1, 2 or 5 seconds, depending on how the receiver has been set up.
If a replacement power adaptor is needed, they're £12.99 (+ P&P) from https://www.medionshop.co.uk/
Just to further confuse, on the car power adaptor for my MDPPC150, the green LED remains on continuously, since it is simply a power adaptor, rather than the junction between the GPS receiver and PDA, as in the MDPPC250.
Getting older and more senile by the minute !
Philip
skate2create
PostPosted: Tue Jun 20, 2006 12:19 am    Post subject: Reply with quote
cheers guys.
Took the plunge whenI got home and took the charger apart to find the inductor (the one that looks like a resistor) snapped offthe board Sad
so I soldered it backonusing a finepointiron andhey presto...sheworks again Smile
Cheers,
Dan
