Pocket GPS World :: View topic - i3 and locating satellites
jackarmy83
PostPosted: Sat Jun 17, 2006 2:21 pm    Post subject: i3 and locating satellites Reply with quote
Hi all,
Just bought an i3 and updated it to the latest firmware revision. (3.10). Just got in my car to test it out but it's stuck on locating satellites (tried for 10-15 mins).
Does it need to be activated first? No mention of what to do in the user manual that comes with it.
Thanks, Karl
jackarmy83
PostPosted: Sat Jun 17, 2006 2:32 pm    Post subject: Reply with quote
As usual, I've done things arse backwards. Just read the faq section. So will try the advice given there first.
Embarassed
dougconran
PostPosted: Sat Jun 17, 2006 2:33 pm    Post subject: Reply with quote
No, it doesn't need to be activated first but it can take some time to locate satellites the first time you switch on.
Make sure it is outside, has got plenty of open sky around, and doesn't move about at all. If you haven't got a lock in about 30 mins (I think) then you've probably got a problem
HTH
jackarmy83
PostPosted: Sat Jun 17, 2006 2:52 pm    Post subject: Reply with quote
Thanks Doug, just been up on the roof of my flats and it picked it up within about 5-10 mins. :D
Thanks again.
jizzer
PostPosted: Sun Jun 18, 2006 8:40 pm    Post subject: Reply with quote
Thats still a long time I had this problem with the latest firmware(3.10) then rolled back to V2.7 now locks on to sats in under a minute ....always keep a set of batteries in the unit even if you use the cig adaptor this way it sort of retains its memory if you like and locks on quicker
north_country_boy
PostPosted: Sun Jun 18, 2006 9:42 pm    Post subject: Reply with quote
Mine used to lock on in a few seconds on 2.7, now i'm on 3.1 and it took 15 minutes today, not happy, Garmin should sort this out Evil or Very Mad
jackarmy83
PostPosted: Sun Jun 18, 2006 11:09 pm    Post subject: Reply with quote
Maybe I didn't explain myself clearly. Embarassed
I meant it took 5-10 mins for the initial satellite locations (as it was the first time I was using it). Now it picks them up straight away.
supercliff
PostPosted: Mon Jun 19, 2006 1:38 pm    Post subject: Reply with quote
I've found that my i3 can take up to 5 minutes to locate satelites if I haven't used it for a while, esxpecially if I get on the move before turning it on.
But, if I'm at home, it latches on in seconds.
Weird....
Nuvi 660, VW GOLF
23.012 (08 Jan 25)
