john59 Occasional Visitor
Posted: Sun Jun 18, 2006 4:57 pm Post subject: I3 limitations |
I3 limitations.
I use my I 3 every day traveling around the northwest ,and although 95% of the time it will get us there ,but we find that when we are given an address on an industrial estate with just a company name we do struggle although it gets us in the genaral area. Now for the bad bit, We had to do some work in Walkden near Manchester and Walkden is quite a sizable town and the I3 could not find Walkden never mind the street name, it eventualy found the street under Manchester ??????????????? and only yesterday we had to go to the Birch ind estate near haywood Bury and it did not exist on the I3 maps and the estate has been there for over 30 years. When we finaly did get there the triangle on the screen was in limbo so to speak, no roads or rivers just a grey blank screen.
Sorry for the rant guys but has anyone else experienced this.
Regards
John |
alix776 Pocket GPS Moderator
Posted: Sun Jun 18, 2006 7:12 pm Post subject: |
if its the industrial estate im thinking of then it not on any map the building shoud be postcoded though
not all industiral estates are on paper maps even though in the case of birch the a sign a the junction where you turn right heywood distribution park is there as it a much bigger estate something like birch isnt big enough though _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
sunstrip_steve Regular Visitor
Posted: Sun Jun 18, 2006 9:58 pm Post subject: |
Yes it is a little annoying, but its an information issue, not a unit issue. And in general is a problem with industrial estates as the roads are private
sites on this estate do appear with postcodes however.
With the greater manchester area most things are listed under manchester |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15150 Location: Bradford, West Yorkshire
Posted: Tue Jun 20, 2006 8:50 am Post subject: |
it's not a limitation of the i3, it's clearly a limitation in the map data provided by navteq... the i3 can only find what it has been told exists!
you'd find it would be the same on any unit that uses navteq maps...
MaFt |
Posted: Fri Jun 23, 2006 12:27 am Post subject: |
Cheers guys, so postcodes are the way to go |
dab Occasional Visitor
Posted: Fri Jun 23, 2006 6:38 pm Post subject: |
I use my i3 all the time for finding my way to different companies in the North West, and Post Codes are definately the way to go.
You don't quite get "to the door" as companies don't always give a street number. I use No.1 and it usually gets me close enough.
Also, make sure that your i3 has V8 maps, and not the older V7. |
guitareth Occasional Visitor
Joined: May 20, 2006 Posts: 19 Location: Orba, Alicante, Spain
Posted: Sat Jun 24, 2006 3:27 pm Post subject: i3 not so good if you don't know postcode? |
Had my i3 for a few weeks now, and whilst I agree its great when you know the full postcode, it doesn't seem to be so good if you DONT know the postcode. What I don't get is, if I try to enter a destination from just the street name, it very often can't find the street at all in its database, (or it offers me just certain ones of the same name in different towns but not the one I want). However, if I find out the full postcode for the same destination, then it will offer me the correct street and just ask me to select house number.
So how come, when the street I'm looking for clearly IS contained in its database, why is it only offered in the results when I search via the postcode?
Also, when you enter a postcode and get down to the street, it seems it has to be given a house number. This is the case for locations which don't actually have any house numbers in reality. It appears the only way to complete the entry of your destination is to enter a random house number anyway. Is that correct, or am I missing something?
If I 've posted some incorrect statements here, then I'm probably not familiar enough with the correct operation of the unit yet! If so, appreciate any guidance as to how I should be using it in instances as described above. I'm a newbie - be gentle with me _________________ Garmin i3 bought May 06 from www.comet.co.uk for £129.99
Firmware v2.70
Mapsource City Navigator Europe NT v9 Deluxe
Audio v2.30
HTC Desire Android Smartphone
Dilcymro Frequent Visitor
Posted: Sat Jun 24, 2006 8:50 pm Post subject: |
HI guitareth,
Regarding postcodes, if there is no house no then you just enter " 0 " and then the i3 will put you somewhere around the centre of the postcode, near enough for you to find anyway. I have done this a few times and just asked someone where the house is, only to find it was only a few yards from where I was. Basically it puts you in the ballpark.
What I tend to do now is check on the bt site for a phone number check and when it finds it , it gives you the postcode also. Ok if you have some details available.
Regards....Dil _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Shro Occasional Visitor
Posted: Sun Jun 25, 2006 8:32 pm Post subject: Postcodes still don;t work |
Thought I'd share my experience on this with i3
Was searching for a particular address in Slough Industrial estate. the Postcode finder did seem to have the postcode in its database. However when I selected this to get the location, it threw me off by displaying a completely different addres... with a DIFFERENT POSTCODE !! 8O
Wonder if anybody faced a similar situation.
What I then did was (after reaching the place... somehow) added the location to my Favourites and it worked great . :P
The other thing I tried was the laborious way of first identifying the location through Google Earth, getting the Lats & Longs and adding to Custom POIs |
Lester_Burnham Frequent Visitor
Posted: Mon Jun 26, 2006 10:33 am Post subject: Re: Postcodes still don;t work |
Shro wrote: | Thought I'd share my experience on this with i3
Was searching for a particular address in Slough Industrial estate. |
Wasn't Wernham-Hogg was it? ;-) |
Posted: Mon Jun 26, 2006 10:39 am Post subject: Re: i3 not so good if you don't know postcode? |
guitareth wrote: | ...... whilst I agree its great when you know the full postcode, it doesn't seem to be so good if you DONT know the postcode. What I don't get is, if I try to enter a destination from just the street name, it very often can't find the street at all in its database, (or it offers me just certain ones of the same name in different towns but not the one I want). However, if I find out the full postcode for the same destination, then it will offer me the correct street and just ask me to select house number.
So how come, when the street I'm looking for clearly IS contained in its database, why is it only offered in the results when I search via the postcode? |
Anyone care to comment on the above, as I'm wondering if I'm doing something wrong? Is it really the case that you really must know your destination postcode in order to use i3 successfuly? |
Posted: Thu Jul 06, 2006 8:16 pm Post subject: |
BUMP! Anyone care to answer my last question? Please! [/i] |
slatermethuen Occasional Visitor
Posted: Sun Jul 16, 2006 10:38 pm Post subject: |
guitareth wrote: | BUMP! Anyone care to answer my last question? Please! [/i] |
I'm afraid I don't have a solution, but I can confirm that I am also experiencing this problem, and it is very annoying having to look up a postcode when I only know the street name/house number.
E.g. Searching for SO53 4HZ finds Renown Close in Eastleigh, but searching for Renown Close yields nothing in the locality.
Another one: SO14 5RP finds Princes Street in Southampton, but the i3 cannot find this street by name.
Please could some other i3 users confirm this issue with these addresses? These were the very first two searches I have ever performed on my new i3 and, so far, I am not too impressed. Maybe I am making a basic mistake in the way I am doing the search? |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Sun Jul 16, 2006 11:33 pm Post subject: |
I've found both of these on my i3 without a problem.
Where to / Address / England / Eastl (gives Eastleigh, Hants as an option) / House No 0 / Street Reno (gives Renown Close as the only option)
Where to / Address / England / Southa (gives Southampton, Hants as an option) / House No 0 / Street Prin (gives Princes [Close, Court...] as an option) / Select (gives Princes Street as the third option) _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Sun Jul 16, 2006 11:47 pm Post subject: |
Thanks for that!
When I was searching, at the 'City or Postal Code' screen, I was selecting 'Search All'. I assumed that this would search all locations in England, but obviously not |
