Pocket GPS World :: View topic - Navman ICN 530
Navman ICN 530
Goto page 1, 2, 3, 4, 5  Next
jak68
PostPosted: Sat Jun 17, 2006 10:06 pm    Post subject: Navman ICN 530 Reply with quote
I have recently bought the navman 530 and have tried to download the speedcamera database without success,it is saying that it it is downloaded but nothing is showing on my gps, has anyone got any ideas
Tim Buxton
PostPosted: Sat Jun 17, 2006 10:42 pm    Post subject: Reply with quote
Have you read this?
Tim
jak68
PostPosted: Sat Jun 17, 2006 11:39 pm    Post subject: Reply with quote
it is the icn 530 I am using not the 3xx series
peterc10
PostPosted: Sun Jun 18, 2006 12:36 am    Post subject: Reply with quote
When you have downloaded to your PC you have to unzip and install them.
Click on speed cameras to left of this screen. Scroll down the next page until you get a list of sat nav units. Click on your unit and up will pop instructions telling you how to do this.
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
jak68
PostPosted: Sun Jun 18, 2006 8:42 am    Post subject: Reply with quote
I have done all this and it still doesn't work , I had the ICN 520 before and it worked ok with that
Tim Buxton
PostPosted: Sun Jun 18, 2006 9:10 am    Post subject: Reply with quote
Good, then reading the piece I linked to should help.
Tim
jak68
PostPosted: Sun Jun 18, 2006 9:26 am    Post subject: Reply with quote
I have followed the instructions exactly and it doesn't work, after I have done it the first time it asks doI want to overwrite the existing files but there is no speed cameras showing up.
Tim Buxton
PostPosted: Sun Jun 18, 2006 9:32 am    Post subject: Reply with quote
If it asks if you want to overwrite the existing files, it sounds like you aren't renaming the files as you go. Using the default filename will result in all the files being called POCKETGP or something similar.
You need to rename each one in turn. I call them GATSO2O, GATSO3O, ect.. Note that for some reason the 0 (zero) key doesn't work, at least for me, in this operation, so I use the letter 'O' to represent a zero. This renaming is done at the 'POI File Name' stage.
Also I have the 'Visibility' slider set to 'High', i.e. fully to the right. Both of these have screenshots in the helpfile I linked to.
Tim
jak68
PostPosted: Sun Jun 18, 2006 9:39 am    Post subject: Reply with quote
thanks tim, I have tried all this, still nothing . when I go in to my data on my 530 there is nothing stored in my POI files, shouldn't it show up in there?
Tim Buxton
PostPosted: Sun Jun 18, 2006 9:48 am    Post subject: Reply with quote
The files should be in the directory
My Flash Disk/Navman/Lightning/Navman/MYPOI
Each custom POI is made up of three parts, those having .bm, .ini and .map extensions.
Are your POIs listed under
Preferences/My Data/My POI and if so are they checked?
Tim
freedy50
PostPosted: Sun Jun 18, 2006 11:53 pm    Post subject: Reply with quote
And i thought it was just us 'forum rank' people who had this problem!! Confused Any idea if it can be resolved Question
larrylad
PostPosted: Mon Jun 19, 2006 12:53 am    Post subject: rename files? Reply with quote
i am also having problems putting the camera database on my navman 530 its just a shame that all this extra info about renaming the gatso files ect is not mentioned in the link that tells you how to install them in the first place, maybe me and others would not be wasting our time and pulling my hair out if it was included - maybe an update needs doing?
Tim Buxton
PostPosted: Mon Jun 19, 2006 6:40 am    Post subject: Re: rename files? Reply with quote
Well it clearly says that you should choose a name to appear within the Navman software. I know what happens when I call two files by the same name and save them to the same place.....
Although an update is needed, as 150' is far too short a distance. 1500' is more realistic.
Tim
jak68
PostPosted: Tue Jun 20, 2006 9:30 am    Post subject: Reply with quote
I have checked all the above and for some reason on my computer, there is no stored 'ini' extension, but the bm and map extensions are there.
Any ideas ? I have tried doing this about six times and the same thing happens.
Tim Buxton
PostPosted: Tue Jun 20, 2006 7:34 pm    Post subject: Reply with quote
I really have no idea at all. Would you like me to email you my .ini files (I have the 23 separate ones) and you could try putting them into the correct directory and reset the iCN. It may work, it may not. Otherwise, I suspect a call to Navman Tech Support will be in order.
Tim
Page 1 of 5
22.094 (25 Sep 24)
