Pocket GPS World :: View topic - NEW GO 910 FIRMWARE!!!!!
Goto page Previous  1, 2, 3, 4, 5  Next
steveJ
PostPosted: Fri Jun 16, 2006 2:33 pm    Post subject: Reply with quote
One thing I have noticed with the new download is that it will announce when my phone connects and tells me which model the phone is using the TTS software, and it also announces that the phone is disconnected when I switch the phone off.
Steve
eddie_vincent
PostPosted: Fri Jun 16, 2006 2:40 pm    Post subject: Reply with quote
Sometimes it does, sometimes it doesn't!
Paul
TT Go 940
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
ICQ Number
westentertainer
PostPosted: Fri Jun 16, 2006 4:16 pm    Post subject: Reply with quote
why cant i get it what am i doing wrong guted1111
westentertainer
PostPosted: Fri Jun 16, 2006 4:30 pm    Post subject: Reply with quote
got it now
Make sure your internet connection is open (you might want to try disabling any firewalls - just incase), connect the Go x10 to the home mount and PC.
When the Home application starts up on the PC it should ask you to "check for updates?" if it doesn't you have probably disabled the facility to auto check each time.
Click the light blue spanner icon (top LH of the TT Home Application, then in the preferences box that will appear you can either press the "Check for Update" button, but at the same time you might consider checking the box labeled "Check for updated content when I'm logged in and my TomTom device is connected to the computer"
Hope this helps - Mike
westentertainer
PostPosted: Fri Jun 16, 2006 4:33 pm    Post subject: Reply with quote
what i did was tick the square it tomtom applications and it downloaded a litle egg timer icon on 910 and then it was there many thanks
pepperm
PostPosted: Fri Jun 16, 2006 7:15 pm    Post subject: Reply with quote
I installed 6.110 yesterday and it worked fine until I powered off the 910. I couldn't then get it back on again until I spent some time pressing the reset button and placing it on and off the USB desk stand. The power button and reset button wouldn't work on their own. I could only get my 910 back by using the USB stand.
Since then I have had no problems powering on and off, I did have a small heart attack though last night.
Mark
jean
PostPosted: Fri Jun 16, 2006 7:27 pm    Post subject: Reply with quote
Same as me pepperm! See other thread!
Just worried that it will happen again now. Sad
lydiachris
PostPosted: Fri Jun 16, 2006 7:29 pm    Post subject: Re: MP3 Player? Reply with quote
mikealder wrote:
lydiachris wrote:
Has the mp3 player been fixed also? Mike if you could try this out, i'm not going on any long distance drives for a while. Before i kept on getting errors like "an error has occured whilst..."
Its early days on this one, but having just tried it on a 40 mile run (checking the POIWarnings) I did a number of power downs and restarts hitting resume for the mp3 each time five re-powers, and never suffered a problem once with the mp3, interestingly my Audio books have also re-appeared, I had given up on them to be perfectly honest!
lydiachris wrote:
I like you VERY ingenious idea of "tricking" the go 910 by using 2 warnings. Fantastic, well done Wink
Good I am glad you like that, because you will need it, living in Blackpool it is very easy to access roads with loads of similar cameras at the same type/ speed (try the promenade - seven miles nine GATSO@30), as its a straight run, you get no navigation prompts to reset the device, I got the first warning then nothing but flashing cameras on the screen no audio. If you enable my dodge as posted above you get an alert for every one of them (return trip)
lydiachris wrote:
Did you get to try out the POI warning?
Yes please read above para, its still the same!!
Mike
Thanks a lot Mike for all this information. You know, we could work for tomtom support, I think we would provide a LOT more useful help for asking customers!!! Wink
I've tried your POI trick and it works perfectly. Let's just hope TomTom solve it in their next firmware update 8O
What I have noticed that on the mp3 player, when I tap on "playlist" i've got a so called playlist named "mp3" which wasn't there before and no folder/playlist exists with the name mp3. has anyone else got this??
Ha, I can't believe i've found all the answers to my questions in this one thread! Well done guys :D
Keep it up,
lydiachris
PostPosted: Fri Jun 16, 2006 7:46 pm    Post subject: Reply with quote
Carry a pin or needle in the lid of the soft case (I have done since day one!) - you never know when it will be required - Mike
jean
PostPosted: Fri Jun 16, 2006 8:14 pm    Post subject: Reply with quote
Thanks for the tip - We are off on holiday soon and have already decided that we have to take a sewing kit for the tomtom! Smile
mrstella
PostPosted: Fri Jun 16, 2006 10:04 pm    Post subject: Reply with quote
I got the mp3 error for the first time today, so i would assume its not been fixed.
andyhat
PostPosted: Fri Jun 16, 2006 10:34 pm    Post subject: Reply with quote
how do i find out what app ive got.
tt go510.
n70.
andyhat
PostPosted: Fri Jun 16, 2006 10:36 pm    Post subject: Reply with quote
ive downloaded the new updates but ive still got 6.020 on mine.
tt go510.
n70.
hegedusa
PostPosted: Sat Jun 17, 2006 12:02 pm    Post subject: Reply with quote
eddie_vincent wrote:
Remote Control now works with Traffic correctly.
What was wrong with the remote and traffic before? I never had a problem. Or maybe I just think I never had a problem and never noticed what was actually wrong.
Anthony
Page 2 of 5
23.053 (21 May 25)
