Pocket GPS World :: View topic - TomTom Navigator and Arkon GPS Setup
JonnyC
PostPosted: Mon Sep 19, 2005 1:57 pm    Post subject: TomTom Navigator and Arkon GPS Setup Reply with quote
I have an Acer n30 with TomTom Navigator 5 installed and have a Arkon CM885 Powered GPS
PDA Mount; they are connected together via USB cable attached to the port on the bottom
of the PDA and the data usb slot on the bottom of the gps mount. I am having trouble
setting the TomTom software on the PDA up with the Arkon GPS Mount, I presume you chose
the 'Other Cable NMEA GPS' device as GPS hardware, I set the baud rate as default (4800)
but am unsure which connection to choose for data transfer between the two devices, the
options are:
BT UART2
SC2410 USB Cable:
Com3:
S2410 IRDA2410
S2410 UART0
S2410 BT UART2
Bluetooth Serial Port COM6:
Bluetooth Serial Port COM5:
Any help appreciated. Jon.
JonnyC
PostPosted: Sun Sep 25, 2005 9:09 am    Post subject: Reply with quote
Bump
AlanEarle
PostPosted: Tue Sep 27, 2005 6:01 pm    Post subject: Reply with quote
I Have exactley the same Problem with an Orange SPV not just with TomTom
but with an GPS software.
gune
PostPosted: Mon Nov 28, 2005 2:35 am    Post subject: any luck Reply with quote
hi
any luck so far?
did u ask from arkon guys?
if u r successful can u please post?
thanks
JonnyC
PostPosted: Sun Dec 04, 2005 12:31 pm    Post subject: Reply with quote
No I gave up and bought a Garmin StreetPilot i3 instead. Ended up selling the Arkon Mount on eBay. Good luck...!
alix776
PostPosted: Sun Dec 04, 2005 1:02 pm    Post subject: Reply with quote
in the connections tab on the pocket pc uncheck recieve all incoming beams then select usb by the looks of it
device Lumia 950 xl
Snake_Plissken
PostPosted: Fri Jun 16, 2006 5:45 pm    Post subject: Reply with quote
Been there done that, still no joy, have sent email to Arkon asking if unit compatible with TT5.21
FrequentFlyer
PostPosted: Fri Jun 16, 2006 6:01 pm    Post subject: Reply with quote
I have a powered Arkon working just fine with an IPAQ PDA running 5.21. Settings are, NMEA device, 4800 Baud, and SerialPort Com 1.
FrequentFlyer
PostPosted: Fri Jun 16, 2006 6:04 pm    Post subject: Reply with quote
ps You sure you haven't got one of these funny windscreens that sort of, blocks the signal out somehow ? My wifes Ford KA has a heated screen which really plays havoc with the Arkon, so I bought her a blue tooth Holux 236 which is totally magic and so flexible...beats the all in one Arkon any day.
FrequentFlyer
PostPosted: Fri Jun 16, 2006 6:06 pm    Post subject: Reply with quote
With all due respect, 521 has nothing to do with it...a GPS receiver is a GPS receiver...it's in the settings or the car screen..I believe.
22.064 (26 Jun 24)
