Pocket GPS World :: View topic - POI Loader 2.3.1
POI Loader 2.3.1
Goto page Previous  1, 2
mrklaw
PostPosted: Wed Jun 14, 2006 8:13 pm    Post subject: Reply with quote
I'm new to all this lark, so please be gentle.
Does this new version (the only version I've downloaded having only bought my nuvi today) mess POIs up? I used manual for speed cams, but have to start playing with Ash and cbroms tools too.
I don't have any other POIs on there just yet, so should I leave them off until the software is fixed?
Could someone point me to where I could get the older version?
timber
PostPosted: Wed Jun 14, 2006 10:01 pm    Post subject: Reply with quote
mrklaw wrote:
There seems to be some problems with the lattest release i have put the previous release on my web space to enable anyone to download .
Will leave untill i need the space for something else.
http://makeashorterlink.com/?X1094354D
mrklaw
PostPosted: Wed Jun 14, 2006 11:14 pm    Post subject: Reply with quote
cheers, grabbed it just in case. :D
Lester_Burnham
PostPosted: Thu Jun 15, 2006 3:22 pm    Post subject: Reply with quote
Right, I've tried both modes of the new POIloader, now - express and manual mode.
Most of MaFt's POI files, plus the safety camera database (ie the files grouped as type of camera - redlight, temporary, mobile, etc...). The safety camera files are in gpx format after using cbrom's utiltiy.
Before this new version of POIloader, all the POIs worked as you'd previously expect - however, with the new version using either express mode OR manual mode, all POIs on route cause proximity alerts - EVEN if using manual mode, and only selecting proximity alerts for the safety camera files.
So deffo some kind of bug with it, I'm going to revert to the previous POIloader version and re-load my POIs.
chrisbl99
PostPosted: Fri Jun 30, 2006 5:55 pm    Post subject: Reply with quote
I'm having the same problem, but I only have version 2.3.1. I tried the version 2.0 and it crashes on the XP system. Could someone please point me to version 2.2.1 so that I can remove the proximity alerts...they are driving me crazy.
timber
PostPosted: Fri Jun 30, 2006 6:40 pm    Post subject: Reply with quote
Welcome to the forum Chris,
sorry to hear your having problems, there are only 3 versions of the POILoader Software.
Original version, i can put on my web space but will need to remove version 2 first let me know if you want this Question
Here is another location of version 2 http://www.gpsinformation.org/perry/POILoader_20.exe
Version 2.3.1 is the current version obtainable from http://downloads.garmin.com/POILoader_231.exe
Suggest you un-install the POILoader you currently have shutdown/restart your computer and download and install the programme from gpsinformation.org
There is something wrong with the download you have previously obtained (corrupted during downloading) as it should not give problems crashing XP, sounds like the problem is at your end.
chrisbl99
PostPosted: Fri Jun 30, 2006 7:39 pm    Post subject: Reply with quote
Thanks very much. I'll deinstall 2.3.1, reboot and then try the old version again. If I need the other version I'll let you know.
Thanks again
Chris.
chrisbl99
PostPosted: Sat Jul 01, 2006 1:32 pm    Post subject: Reply with quote
Timber,
That worked a treat..thanks. I've updated my POIs using 2.2.1 and it's no longer alerting for general POIs, just the speed cameras.
Thanks again
Chris
sshih
PostPosted: Fri Jul 21, 2006 3:44 pm    Post subject: POI Loader 2.2.1 Reply with quote
Timber,
Hi there, I'm new to this forum. I just purchased the Nuvi 360 so now I'm doing all sorts of additional research about POIs, maps. etc.
I downloaded the new POI Loader 2.3.1 from Garmin but didn't install it yet after reading about their proximity alert issue.
I've been looking all over for the 2.2.1 version. Do you still have that available? I found version 2.0 but I would really prefer to get 2.2.1 if someone still has it out there somewhere.
Thanks for the help.
Looking forward to other helpful tips and tricks about the nuvi and all things related.
cheroksys
PostPosted: Sat Jul 22, 2006 10:53 pm    Post subject: Re: POI Loader 2.2.1 Reply with quote
sshih wrote:
Timber,
related.
I have found version 2.2.1 files located at the following site
http://forums.groundspeak.com/GC/index.php?showtopic=122497&st=100
Download link
http://members.shaw.ca/caccoins/POIloader.zip
Just use these files to overwrite the files from 2.3.1, reboot PC and upload your POI, worked for me Smile
ajsnr1
PostPosted: Tue Jul 25, 2006 6:32 pm    Post subject: Reply with quote
hi new here this in the help file on poi 2.3 yous are having probs with it may help
Advanced users can create their own .csv and .gpx data files that include Custom POI lists or TourGuide files.
POI Loader loads all .csv and .gpx data files saved in a particular folder. When creating or downloading Custom POI data files, it is recommended that you save all the data files you want to upload to your device in one single folder.
POI Loader determines whether or not a file contains speed and proximity alert points based on specific criteria. Use the following information to help you create Custom POI files:
· If a file name contains a valid speed number or if all records in a file have speed encoded in the name, then all records in the file will include speed and proximity alerts. For example, a data file with the file name "Speed_30" generates speed alerts of 30 mph (or kph, depending on the type of units selected in POI Loader) for each POI in the file.
· If the file name contains "redlight", POI Loader assumes all records in the file have proximity alerts with a distance of 400m/0.25 miles
· If a file contains "GATSO," "mobile," "SPECS," "safety," "speed," or "camera," but does not have a speed, POI Loader uses a default alert speed of 0, which means you will always be alerted. You can override this default value by entering the speed in Manual mode.
· You can also enter speeds for each POI individually by adding the @ symbol and a number after the name of the POI. For example, a Custom POI named "Ridgeview@25" would create a POI named "Ridgeview" with a 25 mph speed alert.
· POI Loader calculates proximity alert distance based on speed. You can enter proximity alert distance for individual Custom POIs in a .gpx file. You can also enter proximity alert distance for all Custom P
OIs in a data file using Manual mode.
See Understanding Speed and Proximity Alert Information for more information.
For more information, see the following topics:
Creating Custom POIs in MapSource
Creating .CSV Files
Creating TourGuide Files
Loading Custom Bitmaps
Page 2 of 2
22.055 (29 May 24)
