Pocket GPS World :: View topic - Tom Tom One Clock (again ! sorry)
oldfogy
PostPosted: Sun Jun 11, 2006 3:52 pm    Post subject: Reply with quote
Found my original post.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=41359&highlight=
With regards to number of POIs with different versions, have a good look through some of the other forums or try a search, I'm sure you'll find confirmation of my previous comment.
wazza99
PostPosted: Sun Jun 11, 2006 7:23 pm    Post subject: Reply with quote
Nope no cure as yet for me, just living with it.
oldfogy
PostPosted: Sun Jun 11, 2006 7:31 pm    Post subject: Reply with quote
Not sure but have a look back at this post.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=227417#227417
I think at least in my case the problem is now solved.
But only time will tell.
999tommo
PostPosted: Sun Jun 11, 2006 7:55 pm    Post subject: Reply with quote
I've now upgraded to 5.450 again, as I managed to get my data.chk file sorted to allow my 'Vicky Archer' spoken camera warnings. Apart from the screen brightness, I haven't noticed any change from 5.420. As for my clock, it's working fine and does not reset each time I turn off. I'm wondering if there is something else that has changed in the newer models which causes some kind of conflict with the software ?
Tommo...
Regularly absent, but still here in spirit !
adrianc
PostPosted: Sun Jun 11, 2006 8:00 pm    Post subject: Reply with quote
I might be missing something - I can find the "standard" voice download for the Speed cameras but not the voices for Liz Whitaker or Vicki Archer - where are these?
999tommo
PostPosted: Sun Jun 11, 2006 8:10 pm    Post subject: Reply with quote
They are accessed via Ray Flannagan's site...
Click Here
Tommo...
oldfogy
PostPosted: Sun Jun 11, 2006 8:12 pm    Post subject: Reply with quote
I think you need to DL them from here:
http://www.tomtomsatnav.info/realvoice.html
Problem is, for the 5.450 they don't seem to be listed yet.
999tommo
PostPosted: Sun Jun 11, 2006 9:26 pm    Post subject: Reply with quote
Yes, I think the latest are for 5.42, but there are ways and means. I have got Vicky Archer on 5.45 now. I can't remember how I did it, but I'll work it out and post it. It was using an edit programme and all you need is your original data.chk file and you can change all the beeps, bugles etc to the downloaded voices.
Tommo...
luminary
PostPosted: Sun Jun 11, 2006 10:03 pm    Post subject: Reply with quote
Has anyone had this problem with 5.42. I'm running 5.45 on a brand-new unit and have the problem.
Is it possible to revert to 5.42 on a unit which was supplied with 5.45 ?
999tommo
PostPosted: Sun Jun 11, 2006 10:09 pm    Post subject: Reply with quote
Got it.....
I downloaded soundpatcher from HERE then downloaded all the Vicky Archer 22050Hz voice warnings from the bottom of THIS PAGE.
Once you have it all, you simply run the POI soundpatcher programme, select your own data.chk file, then select the appropriate Vicky sounds from the ones you downloaded, into the appropriate fields on soundpatcher and create your new data.chk file.
Once you have all the sounds, every time there is an update, you can alter the new data.chk file with your chosen sounds. If you can sample sounds, you can create your own warning sounds, as long as you sample them at 22050Hz and save them as .ogg files.
Simple Laughing
Tommo...
luminary
PostPosted: Mon Jun 12, 2006 10:58 pm    Post subject: Reply with quote
Ok, I think I have a fix for the clock problem now.
I'd spent hours experimenting with various resets to no avail, and had resigned myself to the fact that I had a hardware problem and I was going to return the unit to the store.
I thought I should phone TomTom support, even though people seem to have tried this before and weren't particularly complimentary of the service received.
As soon as I explained the problem to the TomTom support guy (in fact before I had finished explaining it) he said that it was a know problem that many people are experiencing and that hasn't been fixed yet. He said the workaround was as follows:
* Choose "Reset Factory Settings" in the config page.
* Before doing anything else, reset the unit by pushing a pin into the reset hole and hold this in place for 10 seconds.
* Repower the unit.
To my amazement everything now works OK. Note that you will lose favourites, configuration settings and Home location (but not POIs and POI warning configuations).
I just thought I'd share this in case it helped anyone else
julianbarker
PostPosted: Tue Jun 13, 2006 10:20 pm    Post subject: Reply with quote
I didn't have to return to factory settings. A reset with the pin made the clock work, and I didn't lose my settings etc.
ZeroKool
PostPosted: Thu Jun 15, 2006 10:55 am    Post subject: Clock Reply with quote
Just a reset seemed to work on mine aswell.
oldfogy
PostPosted: Thu Jun 15, 2006 3:46 pm    Post subject: Reply with quote
I have tried 3-4 times to create my own data.chk file but 3 of the original files stay as they are, (I think it was Bell 1,2 and 3). All of the Liz Whittaker files play ok, so they are not faulty.
Any suggestions please.
TT One (5.450)
(If it ain't broke, I can soon fix it)
999tommo
PostPosted: Thu Jun 15, 2006 10:36 pm    Post subject: Reply with quote
It worked first time for me with the Vicky files, although I didn't try Liz. I will give it a shot with those and see if that works.
Tommo...
Page 2 of 4
23.061 (04 Jun 25)
