Pocket GPS World :: View topic - Nuvi loss of satellite signal.
Old_salt
PostPosted: Sun Jun 04, 2006 7:44 pm    Post subject: Nuvi loss of satellite signal. Reply with quote
I have twice lost the satellite signal when I have travelled through the Dartford Tunnel. While I realise the signal will be lost, can anyone explain why my Nuvi does not regain the signals after emerging from the tunnel? I have travelled miles from the tunnel expecting the signals to be active, but they do not. I have cycled powered off/on and the signals returned. Am I missing something or is this normal for the Nuvi? Confused
View user's profile Send private message Send e-mail AIM Address
Jamas
PostPosted: Tue Jun 06, 2006 11:24 pm    Post subject: Re: Nuvi loss of satellite signal. Reply with quote
It is a known default of the SIRF III chipset also present on the 60CSX handset. The Sirf III firmware has been recently upgraded but it does not fix the "tunnel" problem. Waas/ Egnos disable "may" ease the satellite recovery. (To be confirmed)
Only current solution: stwitch the unit off then on.
New Sirf III firmware upgrade will probably solve the problem.
WARNING: Take care not to use WebUpdater as several Nuvi owners have lost their unit during a software/firmware with WebUpdater with this message:" Software missing". Evil or Very Mad
Do the S/W upgrade manually.
Jamas
SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+
Old_salt
PostPosted: Wed Jun 07, 2006 8:41 am    Post subject: Reply with quote
Thanks Jamus,
I thought my problem was unique to my Nuvi only. Thank you also for your warning of the Webupdater, I had recently used it to update the software and did not encounter any problems. I will heed you warning for future updates however. I will try the Nuvi with Waas / Egnos disabled, as I will be using the Dartford tunnel again at the weekend.
Old_salt
Old_salt
PostPosted: Sun Jun 11, 2006 8:00 pm    Post subject: Reply with quote
Wink
As I said in my last post, I would give my Nuvi with Waas / Egnos disabled when I wastravelling through the Dartford Tunnel this weekend.
Well I can say that Jamus was correct, and my Nuvi did search for satellite signal when I emerged from the tunnel.
Thank you Jamus for your suggestion Wink
Old_salt
22.062 (12 Jun 24)
