mr_fuse Occasional Visitor
Posted: Sun Jun 11, 2006 12:20 pm Post subject: Help! cant install 5.21 sd version on my spv m600! |
Can anyone help with this ive been pulling my hair out I put all the contents onto my sd card but nothing happens I was under the impression it was supposed to fire up and start to install? |
alix776 Pocket GPS Moderator
Posted: Sun Jun 11, 2006 3:03 pm Post subject: |
did you have show hidden checked in the sd card propeties before copying it to you computer _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Mullet Frequent Visitor
Posted: Sun Jun 11, 2006 4:16 pm Post subject: Re: Help! cant install 5.21 sd version on my spv m600! |
mr_fuse wrote: | Can anyone help with this ive been pulling my hair out I put all the contents onto my sd card but nothing happens I was under the impression it was supposed to fire up and start to install? |
Best done via active sync. Donwnload TTN 5.2 from http://www.tomtom.com/support/index.php?Language=1&FID=3361 connect your M600 to your PC and run the setup. |
Posted: Sun Jun 11, 2006 5:14 pm Post subject: |
yep tried suggested method but still cant get it running |
Posted: Sun Jun 11, 2006 5:30 pm Post subject: |
Using latest version of active sync and functioning normally?
Starting the "navupd521" file on your PC? |
Posted: Sun Jun 11, 2006 6:15 pm Post subject: |
For a start copy the files to the PC in a specific folder (create one on the desk top to be sure of the location), before you do this make sure as Alex has mentioned to have "show hidden files" checked in Windows Explorer go to Tools/ Folder options, select the View Tab and the show hidden files check box is displayed in the window - make sure Show Hidden files is selected.
Insert the SD card into a card reader, copy the entire contents to the new folder on the PC, then once finished swap the old card for the new one, and copy the CONTENTS of the new folder back to the new card.
DO NOT COPY THE FOLDER AS THIS WILL DESTROY THE FILE STRUCTURE. OPEN THE FOLDER AND SELCT THE CONTENTS RIGHT CLICK SELECT COPY AND THE RIGHT CLICK THE NEW MEMORY CARD SELECT PASTE.
If you have done the above already, how far into the intallation do you actually get? - Mike |
