AllyCat Frequent Visitor
Joined: Feb 23, 2005 Posts: 376 Location: Catford, London, UK
Posted: Wed Apr 26, 2006 4:23 pm Post subject: |
Hi Peter,
Well it's certainly more recent than mine
I think the latest firmware reports 3.1.1 in the first line (mine is 3.1.0) and v5 in the last line (mine is v4).
So you probably don't need a USB data cable, which seems to be 19.98 UKP including VAT and shipping from Clove Technolgy to Denmark.
Cheers, Alan. _________________ Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter. |
Peter322 Occasional Visitor
Posted: Wed Apr 26, 2006 4:33 pm Post subject: |
Good news - thank you soo much for your help.
I think I'll just PM Julie from Holux just in case to check, but it sounds right what you are saying.
Peter |
spikey_w Occasional Visitor
Posted: Wed Apr 26, 2006 5:58 pm Post subject: |
Peter,
Yes you've got the latest version, think I must have been unlucky to get older stock than yours. That's what I see after the upgrade. I had 3.1.0 before. |
Posted: Wed Apr 26, 2006 6:25 pm Post subject: |
Super, I guess I was lucky then - thanks to everyone for your help.
cheers
Peter |
ro-76 Occasional Visitor
Posted: Thu Apr 27, 2006 11:52 pm Post subject: |
spikey_w wrote: | Peter,
I just got mine from Nav4all today, and cannot get a fix. I have the old firmware:
$PSRFTXTVersion GSW3.1.0-SDK_3.1.00.07-C24P1.00 *46
$PSRFTXTTOW: 0*09
$PSRFTXTWK: 1313*49
$PSRFTXTPOS: 6378137 0 0*06
$PSRFTXTCLK: 96250*09
$PSRFTXTCHNL: 12*5F
$PSRFTXTBaud rate: 4800 System clock: 1124.403MHz*5E
$PSRFTXTVersion 236V4 * *4A
This is my second 236. The first had a bluetooth problem, so I returned it to the ebay seller I bought it from, and now this one cannot get a fix. The first unit got a fix within seconds. It was a newer serial number 236-6110 XXX. I may end up returning the nav4all unit and getting a replacement rather than refund from teh ebay seller.
I am a little sucpicious that the nav4all units are refurbished, considering the vary variable firmware, and variable performance reported from other users. It would also explain the lack of retail packaging, mains charger and the low price.
Anyhow, I PM'ed Julie from Holux, so may try a firmware upgrade to try to fix it.
Ro |
Posted: Fri Apr 28, 2006 11:23 am Post subject: |
I finally got a fix this morning, so I'll be monitoring performance. I still have my doubts about the Nav4all units, as to whether they are B-grade stock.
Ro |
JM-HoluxUK Regular Visitor
Posted: Fri Apr 28, 2006 1:06 pm Post subject: |
Hi All,
I have checked with Holux in Tiawan and the stock that Nav4All is not refurb. They simply have got the old firmware onboard. If you are having problems please contact Nav4All who should be able to offer the firmware to you.
If you are still having trouble please feel free to drop me a line & I'll help as best I can.
Cheers,
Julie |
dannyoneill Regular Visitor
Posted: Tue May 02, 2006 8:36 pm Post subject: |
is it possible to get the internal version using bluetooth?
Ive performed cold starts with Sirfdemo, gpsviewe and others but they never show the version info :S |
Posted: Tue May 02, 2006 8:45 pm Post subject: |
Yes. You can use GPSinfo.
Ro |
Posted: Tue May 02, 2006 8:48 pm Post subject: |
Curse my symbian phone :P _________________ Visit Wayfinder Life for all your Wayfinder Navigator needs |
jnjc Occasional Visitor
Posted: Wed May 10, 2006 5:02 pm Post subject: |
How? I tried upgrading through Bluetooth using SirfDemo/SirfFlash without success and had to use the USB cable instead!
HellFire wrote: | I upgraded my 236 through Bluetooth along time ago without a USB cable so why do you need a cable |
fpaliuc Occasional Visitor
Posted: Sat Jun 10, 2006 5:13 pm Post subject: |
I saw on a german site that the last firmware version for Holux 236 is 6.1. Is it true? |
Posted: Mon Jun 12, 2006 11:06 am Post subject: |
I believe thats the latest hardware firmware as opposed to the latest software firmware (which is still 3.1.1 last time I heared) _________________ Visit Wayfinder Life for all your Wayfinder Navigator needs |
AdamPetherick Occasional Visitor
Posted: Wed Jun 21, 2006 5:45 pm Post subject: |
is it just for the updates you need a special cable as I've connected mine to my PC using a standard mini usb cable and it's always worked fine as a wired device |
Posted: Thu Jun 22, 2006 3:16 am Post subject: |
Hi Adam,
That's very surprising as the Holux236 doesn't use a USB interface (protocol) on its connector. The "standard" cable is only for charging the battery. The only way I can see it working is if (one of the following):
- Your "standard" mini USB cable actually includes a USB-serial converter "dongle" (like the "special" Holux cable).
- It's actually communicatting with the PC via Bluetooth.
- It's not a Holux 236.
Or has anyone any other ideas?
