Pocket GPS World :: View topic - Given Tomtom on SD Card, want to install on XDA2i
nebneb
PostPosted: Fri Jun 09, 2006 1:27 pm    Post subject: Given Tomtom on SD Card, want to install on XDA2i Reply with quote
Can anyone help me with installing Tomtom onto my XDA2i from an SD card? Have searched the forums but cannot find anything relevant.
To recap, I have and SD card with Tomtom loaded maps etc and an XDA2i..
Many thanks
PostPosted: Fri Jun 09, 2006 3:01 pm    Post subject: Reply with quote
Were you also given the Product code card? if not you will not be able to activate the map or use the product. The product code card is the same size and feel as a cheque card (plastic with printed code letters and numbers) - Mike
nebneb
PostPosted: Fri Jun 09, 2006 5:59 pm    Post subject: Reply with quote
hi
Yes, the complete package....minus the installation instructions Sad
saudidave
PostPosted: Fri Jun 09, 2006 6:16 pm    Post subject: Reply with quote
You should find everything you need on the tomtom website
PostPosted: Fri Jun 09, 2006 6:56 pm    Post subject: Reply with quote
In which case when you insert the card there should be a folder named 2577, contained in this folder will be a number of installer files, tap each one to install the application, then register the product code.
If there is no 2577 folder or it is empty, go to www.tomtom.com and download the latest application (TTN5,21) and install this to the phone from the PC, either way will work - Mike
