Pocket GPS World :: View topic - I3 won't work on batteries
mccstuff
PostPosted: Wed Jun 07, 2006 4:16 pm    Post subject: I3 won't work on batteries Reply with quote
As the subject title explains I can't get my I3 to work from batteries. When it's plugged into the 12v socket in the car it works no problems.
I'm using NMH Rechargeables that have just been recharged this morning and they work in other devices. I've tried with regular alkaline batteries as well but no luck.
Has anyone had a similar problem?
I would be very grateful for any info.
PostPosted: Wed Jun 07, 2006 4:24 pm    Post subject: Reply with quote
It should work on batteries, albeit not for too long as it goes through them very quickly, make sure you have told the device you are using NiMH batteries though go to Settings/ System/ Battery Type and you can select either Alkaline or NiMH. Mike
mccstuff
PostPosted: Wed Jun 07, 2006 8:31 pm    Post subject: Reply with quote
I have set it to NMH batteries, but stll no luck running on batteries. The journey home was ok via the 12v socket.
Pootle
PostPosted: Wed Jun 07, 2006 8:59 pm    Post subject: Reply with quote
If your unit is running off in car power lead but also with batteries in and you pull out the power lead what happens?
Might sound like an obvious question I guess but give it a try and report back.
Enjoy? WTF?
(S)ad
(A)nd
(P)roud
i3, V8, V2.7, WAAS EGNOS.
Audio V2, Simpsons Voice File
zogman
PostPosted: Wed Jun 07, 2006 9:16 pm    Post subject: Reply with quote
have you the batteries in the right way....
mccstuff
PostPosted: Wed Jun 07, 2006 10:05 pm    Post subject: Reply with quote
Pull out the power lead and zilch, it goes off. I have the batteries in correctly.
PostPosted: Wed Jun 07, 2006 10:10 pm    Post subject: Reply with quote
In which case the device is faulty, I would return it to the supplier for a replacement, you should be able to use the device on batteries alone, it just costs quite a bit. Mike
mccstuff
PostPosted: Wed Jun 07, 2006 10:15 pm    Post subject: Reply with quote
Cheers for the quick reply.
The only problem is that I bought the last one in the Woolworths near to where I work and because I love the bloody thing so much I don't want my money back, I want a replacement. I don't think Woolworths will have a replacement.
Would I be able to go direct through Garmin?
mccstuff
PostPosted: Wed Jun 07, 2006 10:25 pm    Post subject: Reply with quote
Got a fresh pair of Duracell, popped the settings back to alakaline and bingo, no problems it works when the external power is removed.
It doesn't seem to like my rechargeables Energizer 2500mah for some reason, although they work fine in my digital camera, 'tis weird.
I'll just have to use Duracells instead of my rechargeables.
Thanks all for your help.
PostPosted: Wed Jun 07, 2006 10:41 pm    Post subject: Reply with quote
Try wrapping the rechargeable cell bodies with tape (insulation or sellotape will suffice) recharge the cells then re-fit and try again, its a common problem with these type of batteries that they short out when packed into a tight space (the i3 is a tight space, and if the batteries touch they will short out and discharge very quickly) - I have experianced solder melt on a few occasions when using NiMH cells, they need to be treated with caution, once insullated they should be OK - Out of interest what make are the cells you were using, Sanyo??
Mike
paulhgc
PostPosted: Wed Jun 07, 2006 11:09 pm    Post subject: Reply with quote
your batteries are knackered i use batteries on a daily basis and they last for over 8 hrs
paulhgc
PostPosted: Wed Jun 07, 2006 11:11 pm    Post subject: Reply with quote
u need 2400 batteries
PostPosted: Wed Jun 07, 2006 11:28 pm    Post subject: Reply with quote
As he is using 2500mAH batteries this is not the problem, having looked at the battery compartment of the i3 it is very easy to short the cell bodies out, when this is combined with high capacity cells (circa 3200mHA - yes you can get these in AA size format) if they do short out and are of a specific type of construction they could electricaly short out, worse still they could catch fire - my advice if using these cells is to wrap the barrel of the cell in thin wall tape as stated above to prevent the shorting out, it is the shorting of the two batteries that causes the rapid discharge and resultant temperature increase - if in doubt stick to using the copper top units - at least they don't catch fire in the device (only in your pocket Embarassed ) - Mike
mccstuff
PostPosted: Wed Jun 07, 2006 11:42 pm    Post subject: Reply with quote
Blimey, Batteries catching fire! Surprised
I'm using Energizer rechargeables, not sure who makes them. If it's such a problem I think I'll stick to the non-rechargeable type.
Thanks for all the info, everyone is very helpful here.
Beerbellybill999
PostPosted: Fri Jun 09, 2006 12:18 pm    Post subject: Reply with quote
I use Enegizer 2100mah but somtimes the unit will switch off even thougth they are fully charged. The solution was to reduce the brightness down to level 2 and now i get about 5 hours.
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
