jimbokb Frequent Visitor
Posted: Tue Jun 06, 2006 5:24 pm Post subject: Twin Go 300 Issues |
Answer me this.
In front of me I have My TTg 300 & a mates from work.
His TTG is running V5.200
Mine is running V5.420
Both have same Birthday within 14 days (May 2005)
Without the use of external aerial my mates gets 5 to 8 sats all the time & does not EVER lose signal.
Mine however goes from ZERO to three max three Sats & continually loses signal, again without External aerial.
Is my TTG 300 faulty ?
I have monitored both Go's for a couple of hours (yes I know its sad)
Do I really need to go back to V5.200 to get better performance from my unit. ??? _________________ TTG 300,External Aerial
1Gig Viking SD, 512 Viking SD(Backup)Nokia 6680 (o2), 512 MMC
Map Great Britain v 562 App v 6.150 , GPS v 1.21 Boot 4.29, OS:1221 |
lbendlin Pocket GPS Staff
Posted: Tue Jun 06, 2006 5:29 pm Post subject: |
I don't think you can get better performance by downgrading the software. (Try it out, swap the SD cards around).
I'd think your antenna circuit is faulty. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Jun 06, 2006 5:44 pm Post subject: |
Yep you are right, there is problem with my go, my mates got a signal almost straight away (8 sats)
Mine however took nearly 4 mins & then only got 2 sats.
5 mins later my mates has 9 sats but mine has only 3.
Looks like the repair shop for me or maybe buy a new model. _________________ TTG 300,External Aerial
Andy_P Pocket GPS Moderator
Posted: Tue Jun 06, 2006 6:17 pm Post subject: |
I sent my 300 back to TomTom for repair/replacement because the signal level dropped as soon as the multipin connector mated with the one on the mount, although I THOUGHT it was OK the rest of the time.
The one I got in return was vastly better at reception all round. |
Posted: Tue Jun 06, 2006 6:18 pm Post subject: |
Don't forget you should have a 2 year guarantee, and once you've got TT to accept there is a problem, they have a very quick and efficient returns procedure. |
Posted: Tue Jun 06, 2006 6:23 pm Post subject: |
Hi Andy, long time no speak.
I will get onto them first thing tomorrow.
P.S. Did not realise there was 2 year guarantee.
Cheers _________________ TTG 300,External Aerial
Eldar Pocket GPS Moderator
Posted: Wed Jun 07, 2006 12:45 am Post subject: |
A couple of things - never test the units side-by-side, they will be affected by each other; the very first 300 units did not have the foil shield at the bottom of the motherboard and also all the metal bits inside the unit are effectively a part of the antenna system. There are a number of ways to improve the GPS reception by they are pain in the a**e to implement. |
