davtran Occasional Visitor
Posted: Mon Jun 05, 2006 6:19 pm Post subject: Tomtom Go 910 won't remember settings |
I bought a Tomtom 910 this week and Im having nothing but problems
I have tried altering the settings, hard reset etc etc but my 910 will not remember the settings I give it i.e it switches the screen off when I reach over 7o mph and if I remove the tick from the volume command to work without cab noise it continues to turn down the volume?? I fear the software is bugged any help appreciated. |
lydiachris Regular Visitor
Posted: Mon Jun 05, 2006 6:50 pm Post subject: |
Hi, I can help you with the screen turning off when you go over 70mph...
firstly you shouldn't be going this fast Haha.
If you tap the go 910 screen, under preferences, then safety preferences in the first menu, it will firstly ask you if you want to disable or enable the safety feature, ignore this and tap continue at the bottom. Here you will find where you can change the speed at which the screen turns off or have it never turn the screen off. I've set mine to 80mph as 70mph is too low especially if your wanting to overtake somebody.
Hope this helps.
lydiachris |
Posted: Mon Jun 05, 2006 10:31 pm Post subject: |
Thanks yes Ive done all of this but it still turns off having read this forum it seems theres a problem with the cradle connection however there are other commands the machine doesnt remember the most annoying being the volume decreasing with the level of noise in the cab of my van, I have turned it off in preferences but it continues to keep dropping the volume :-( HELP!) |
Posted: Tue Jun 06, 2006 10:02 am Post subject: |
Ah sorry, i thought you meant that the screen displays the next turning when you go over a set speed
Yes many people have had problems with their mounts. They have either returned it to tomtom or where they bought it from. Others have taken the mount apart and re-soldered it. As they appear to be dry-jointed.
It's up to you.
lydiachris |
