Pocket GPS World :: View topic - BC-307 working faster than 4800 with PDA?
david77
PostPosted: Tue Dec 02, 2003 12:35 am    Post subject: BC-307 working faster than 4800 with PDA? Reply with quote
The default baud rate is 4800. I tried to change it to higher speed and it stopped working. Is there a way to change to higher speed when working with PDA to improve response time and performance?
Thank you
PostPosted: Wed Dec 03, 2003 11:05 am    Post subject: Reply with quote
No, the BC-307 is fixed at 4800bps. To be honest even if you could change the port speed you would see no discernable performance increase.
anewman
PostPosted: Sun Jul 11, 2004 5:29 pm    Post subject: Reply with quote
I'm sure i have seen this changed on mine with a utility from Leadtek called WinCEmonitor.
Hunnymonster
PostPosted: Mon Jul 12, 2004 12:12 am    Post subject: Reply with quote
You can change it using something like GPSTweak - but you'll find that it still only provides updates at 1Hz - it just takes less time to convey that message (at 4800baud, you can fit ~500 characters in 1 second of transmission)
The visible effect is at best negligible.
23.012 (08 Jan 25)
