Pocket GPS World :: View topic - Camera Warning and Sound on Demo Journey
Timmytina
PostPosted: Sun Jun 04, 2006 11:23 pm    Post subject: Camera Warning and Sound on Demo Journey Reply with quote
Hi Folks,
My first post, good evening.
I have just downloaded the single file "Hope this contains all the cameras", onto my Tomtom ONE.
Just as a test, I set up the warnings in the POI's for cameras and petrol stations, I then did a demo journey where known cameras and petrol stations were located.
Petrol stations were detected, but cameras were not !!!.
So, the question is:
Are cameras detected on the demo routes, or do I have a problem?.
PostPosted: Mon Jun 05, 2006 12:10 am    Post subject: Reply with quote
How many other POI categories do you have enabled for warnings?
Did you check the box " only warn when on route" ?
Timmytina
PostPosted: Mon Jun 05, 2006 12:34 am    Post subject: Reply with quote
I have only 2, Cameras and Petrol Stations.
I did not check the box "Only warn when on route".
But I have carried out another test with the box ticked, no change.
Looks like I have a problem !!!...
PostPosted: Mon Jun 05, 2006 12:41 am    Post subject: Reply with quote
deselect the petrol stations for now, and only select the cameras. When you test the sound, make sure you can actually hear it. Set the warning distance to 250 metres, and then plot a route that's generously starting before a camera. Do not change the demo speed, 200% is the maximum for the alerts to work.
JockTamsonsBairn
PostPosted: Mon Jun 05, 2006 12:48 am    Post subject: Re: Camera Warning and Sound on Demo Journey Reply with quote
So you've got the Camera POIs set to "warn when near"?
What speed did you run the demo at? I've noticed that you (sometimes?) don't get the warnings when running faster than the default (200%?).
Jock
Timmytina
PostPosted: Mon Jun 05, 2006 8:15 am    Post subject: Reply with quote
Thanks for the replies folks.
I have carried out all of your suggestions, and I have run another demo route at default speed, still no result.
More head scratching me thinks...
I will try an actual run today passed some cameras to do a factual test.
Timmytina
PostPosted: Mon Jun 05, 2006 9:29 am    Post subject: Reply with quote
Just had a look at the file names from the single file download, and I noticed that the 2 files are named with europe :
pocketgps_europe 12KB 0v2 File
pocketgps_europe 1KB Bitmap Image
May have downloaded the wrong file, although I can't remember having the option for the UK.
Will have another look later, after the actual road test.
peterc10
PostPosted: Mon Jun 05, 2006 10:20 am    Post subject: Reply with quote
You have indeed downloaded the wrong file. Still you will be warned of any cameras in France, that is if you ahve the French map.
Peter
HTC Sensation
Copilot for USA
Timmytina
PostPosted: Mon Jun 05, 2006 2:33 pm    Post subject: Reply with quote
Yes that was the problem, wrong area downloaded.
Must remember top put my glasses on more often, and sort my fingers out too..
Working fine now, thanks for all who offered help, much appreciated.
22.062 (12 Jun 24)
