Pocket GPS World :: View topic - Firmware release 3.10
Goto page Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
Rodonn
PostPosted: Sat Jun 03, 2006 12:34 pm    Post subject: Reply with quote
Dumb question of the day....
I've scan read this forum... had anyone upgraded then forced a hard reset?
For clarity
Assume the unit is 2.7 V8 Maps.
Back up faves
Upgrade 2.7 - 3.10
Force Hard reset (I've seent he button combo on here somewhere... I think its turn on unit while holding in <-- and Wheel... please verify)
Reinstall faves.
Garmin StreetPilot i3
maps - v8
f/w - 2.7 with Audio 2.00
GPS Mode - WAAS/EGNOS
Snooper OEM repeater ant. routed to rear parcel.
Snooper Neo S3R user.
Tried - 2.9 (not a good time)
timber
PostPosted: Sun Jun 04, 2006 2:35 am    Post subject: Reply with quote
For clarity
Back up faves
Upgrade 2.7 - 3.10
Reinstall faves.
If your unit performance with firmware 2.90 was far from satisfactory then loading 3.0 or 3.1 will make no difference as no changes to the fimware apart from audio updates occured.
The reset procedure you quote is correct as is the need to back up your favorites carring out this procedure after installing 3.1 will make absolutely no difference to the unit.
I have tried all the firmware and always go back to Beta 2.82 Thumbs Up the poi problem is not an issue for me.
PerseusTheseus
PostPosted: Mon Jun 05, 2006 9:26 am    Post subject: Reply with quote
For clarity
Back up faves
Upgrade 2.7 - 3.10
Reinstall faves.
Yes i did just that, when i bought my unit i had version 2.9, i updated to 3.0 then when installing version 3.1 i decided to install the extra language packs, which seemed to take forever... so i switched my unit off during the instalation of languages then hard reset it, luckily i have still not encoutered any problems !
Regards
PerseusTheseus
sunstrip_steve
PostPosted: Tue Jun 06, 2006 8:30 pm    Post subject: Reply with quote
Well after 700 miles of testing of 3.10 i had 1 crash in Birmingham (of the i3 not my car) after i persisted in going the way i wanted to, not they way it wanted too. This required a switch off and on again. Other than that it seems to calculate routes faster than 3.00 and 2.90, but the other issues are teh same, such as the inaccuracy, which i only really notice in town. and the occasional phantom recalculation.
got an email from tech support suggesting a hard reset and reinstalling 3.10, so i did that, and after 600 miles testing it seems to be exactly the same as before!
So i would say don't worry about the hard reset.
Rodonn
PostPosted: Wed Jun 07, 2006 3:46 am    Post subject: Reply with quote
For clarity
Back up faves
Upgrade 2.7 - 3.10
Reinstall faves.
alas POI is an issue for me, so I'll stick with 2.7 until you guys says its a goer.
maps - v8
alan_t
PostPosted: Thu Jun 08, 2006 4:52 pm    Post subject: Reply with quote
used the i3 today with 3.10 installed.
i noticed the the map being slow to update straight away, and was way out.
also the i3 frooze 3 times in a period of a 120 mile journey.
oh well back to 2.7.
as any one still got v2.82 firmware?
Beerbellybill999
PostPosted: Thu Jun 08, 2006 4:57 pm    Post subject: Reply with quote
a link to all i3 firmware
http://www.gpsinformation.org/perry/streetpilot/sp_ix/
I hope this helps
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
alan_t
PostPosted: Thu Jun 08, 2006 5:45 pm    Post subject: Reply with quote
I hope this helps
thx for the link dude.
Marty-Party
PostPosted: Thu Jun 08, 2006 11:21 pm    Post subject: Reply with quote
I have tried 3.10 and so far in track up map display mode it seems to update at the same rate as 2.70.
However, yesterday I did get multiple freezes when trying to calculate a route. It stuck on 0% but strangely the map could be seen behind the dialog box and it was updating OK.
Maybe the cause of the freeze is somewhere in the route calculation code?
The only fix I could find was to force a power off by holding down the power button. I had to do this 3 times until eventually I got a successful route calculation. Since then it's been OK again - weird.
I think I'll keep 3.10 for a few more days before deciding whether to reurn to 2.7.
Anita
PostPosted: Thu Jun 08, 2006 11:41 pm    Post subject: Reply with quote
I've had exactly the same thing happen twice recently using 2.7. But I had never experienced this until I installed 3.1 and then reverted to 2.7 Confused
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
alan_t
PostPosted: Fri Jun 09, 2006 5:01 pm    Post subject: Reply with quote
mines been freezing in map mode.....i have'nt tried plotting a postcode in yet.
so not noticed the delay in calculating precedure.
Rodonn
PostPosted: Sat Jun 10, 2006 10:08 pm    Post subject: Reply with quote
It really begins to sound like the 'hard' reset is pretty damned 'soft', unless it's a POI.
maps - v8
Attercop
PostPosted: Sun Jun 11, 2006 12:54 am    Post subject: Reply with quote
galaxy111 wrote:
Having read the posts on this topic, I'm happy that I've never loaded an upgrade since v2.7. My i3 has functioned without problems to an acceptable standard (for me).
"If it ain't broke, don't fix it". Smile"
Let's hope that, sooner or later, Garmin's software programmers will manage to issue an upgrade that works. Confused
Spot on. I haven't loaded newer firmware since 2.7 either and my unit has took me all over the place without issue.
I find reading the feedback on here a good way to save myself from wasting time upgrading to crappy versions.
dicko-1
PostPosted: Mon Jun 12, 2006 12:26 am    Post subject: Reply with quote
brought 3i with 2.7firmware updated to 2.9 did not like it went back to 2.7 never been the same since tells me to turn to far in advance white screen lockups takes ages to locate satalites did not have these problems when i fist purchased 3i
north_country_boy
PostPosted: Mon Jun 12, 2006 9:02 am    Post subject: Reply with quote
Same here, I'm on 3.1 and yesterday gave a it a good test by going to Holmfirth, West Yorks. It was all going well until it decided to lose its satellite fix and wouldn't find it again, had to stop for about 5 minutes until it locked on again, then it did a couple of random re-calculating moves, even though I was on the correct road, then the position arrow on the screen was about 3/4 inch from the road i was on. All very odd, but at least it got me there and back, but i'm worried about going back to 2.7 incase I have the troubles others seem to have when they go back. Confused
Page 8 of 11
