Pocket GPS World :: View topic - POI Capture - on TOM TOM 700
johnwille
PostPosted: Thu Jun 01, 2006 8:16 pm    Post subject: POI Capture - on TOM TOM 700 Reply with quote
Hi, Can anyone help? I am running a Tom Tom 700 and having trouble installing POIcapture. I have followed the installation instructions on the site but it still does not display the Capture Icon. I have uploaded the 5.202 system software succesfully. Please help
John
Oldboy
PostPosted: Thu Jun 01, 2006 10:23 pm    Post subject: Reply with quote
Is there a reason why you are using 5.202?
I ask because the later versions of POICapture are better.
The loading instructions are nearly the same for each version.
Can you give some idea of what you've done - which files you've loaded where, etc.
It saves having to guess, and then getting it wrong.;)
johnwille
PostPosted: Thu Jun 01, 2006 11:37 pm    Post subject: Reply with quote
I had version 5.201 installed on the Tom Tom 700 but following instructions on thr speed camera database you need 5.202 for POIcapture to work. i have two subfolders in a folder named "GO" on the main directory of he TOM TOM. The subfolders are :"POI Captute" which has files Dixon, POI Capture and another subfolder Icons and SdkRegistry which contains files POICapture, POICapture.cap, tomtom.mnu which was renamed as such from tomtom.700.mnu
Hope that helps
Oldboy
PostPosted: Fri Jun 02, 2006 6:35 am    Post subject: Reply with quote
The 2 Folders, POICapture and SdkRegistry should be in the Root of the SD Card, at the same level as the Map Folder.
johnwille
PostPosted: Fri Jun 02, 2006 7:32 pm    Post subject: Reply with quote
Thanks, I have now uploaded 5.404 as well and it seems all to be working.
Thank you
John
22.062 (12 Jun 24)
