Pocket GPS World :: View topic - Navman 3000 Firmware
dh
PostPosted: Sun Nov 30, 2003 1:14 pm    Post subject: Navman 3000 Firmware Reply with quote
I am trying to find out if there are any utilities that will enable me to have a look at the firmware version that is running on my jacket.
I recently sent my system away for repair so want to make sure everything is upto date.
What other information will I be able to view with such utilities ?
Cheers,
PostPosted: Sun Nov 30, 2003 1:31 pm    Post subject: Reply with quote
You can use WinFast Navigator available on our Leadtek tools section of the downloads page. If you initiate a cold start and view the development page in WinFast and pause the screen you should see the first 4 or 5 lines will give you firmware and ROM versions.
dh
PostPosted: Sun Nov 30, 2003 3:12 pm    Post subject: Reply with quote
Thanks I have found the versions which are version 2.1.1M01325 Navman Ipaq 2.1.2 - not sure if this is good ? are there any known errors with these versions? I am now looking for the serial number - is this readable with this software?
dh
PostPosted: Sun Nov 30, 2003 3:55 pm    Post subject: Reply with quote
PostPosted: Sun Nov 30, 2003 5:44 pm    Post subject: Reply with quote
2.1.1M01325 basically means it can be either a 3400 or 3450. If you check the next line it will tell you the version.
e.g. $Navman iPaq 2.x.x
If you have 2.1.2 it's a 3400, 2.1.3 or above is a 3450. You can also tell if you have the newer 3450 sleeve because it will have an external antenna on the sleeve.
The serial number will be on the sleeve itself.
22.063 (19 Jun 24)
