anjow1 Occasional Visitor
Posted: Wed May 31, 2006 11:46 am Post subject: Antenna for BT-308? (UK) |
Does anyone know where I can get a cheap antenna for the BT-308? I think I have that model just rebranded as Kirrio - the pairing code was the same and it is identical in appearance.
I'm looking for a cheap (<£20 ideally) antenna for use in my car.
I also wondered what form these take? Where are they attached? Anything else I should know?
Thanks. |
Posted: Wed May 31, 2006 12:04 pm Post subject: |
Seems there's no edit post function.
I was also wondering whether, having got an antenna, I could hide the receiver out of view and it still work. I was thinking that with the antenna attached it would still get a signal without being able to see the sky, meaning I could hide it away so passers by wouldn't be tempted to steal it if I leave it in the car.
My main reason for posting is because I don't understand which antennas would be compatible, or how they connect. |
timber Frequent Visitor
![](modules/Forums/images/avatars/6067967964558399c7ec28.jpg)
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Wed May 31, 2006 12:55 pm Post subject: Re: Antenna for BT-308? (UK) |
anjow1 wrote: | Does anyone know where I can get a cheap antenna for the BT-308? I think I have that model just rebranded as Kirrio - the pairing code was the same and it is identical in appearance.
Thanks. |
Just had a look the following type would fit AT-65-MMCX double check with the seller first.
Antenna can be obtained from various outlets why not try the retailers on the right hand coumn who support the forum (if its cheap, really cheap then ebay is your best bet ).
With the antenna fitted you could place the BT-308 any where you like (under the seats, in the boot remember that it will still be connected by cable to the antenna) just check the bluetooth functionality. |
Posted: Wed May 31, 2006 1:00 pm Post subject: |
I was not sure which retailers were okay to buy from - I see a link to PDAMods but they are frequently slammed in the retailers to buy from/avoid forum... |
Posted: Wed May 31, 2006 1:25 pm Post subject: |
Excellent, thanks very much! |
