Pocket GPS World :: View topic - Detail Map Problem - Loading
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan
JimmyD
PostPosted: Tue May 30, 2006 12:15 am    Post subject: Detail Map Problem - Loading Reply with quote
When I attempt to load the detail map from the SD card, via the Card Utilities option in the Meridian's menu, my meridian has a fit & restarts over & over. Each time it restarts, it trys to load the detail map again, waits about 10 seconds, then restartd again! From Mapsend Streets EU this is.
The unit works find with the detail map turned off, however this is far from ideal.
I no longer have a computer with a COM port so I am loading everything from the SD card.
Detail maps worked fine up till now, I have no idea what I have changed.
I have uploaded a new base map (created from mapsend world base map) from the SD card.
I have upgraded the firmware on the unit.
Any ideas on what to do????? Anyone???????? i would be truly greatful!
Cheers.
yearnslow
PostPosted: Fri Jun 16, 2006 11:12 am    Post subject: Reply with quote
I suspect the 'new' basemap has a bearing on this. why did you change the basemap anyway?
If you changed the basemap and then updated the firmware, I suspect that could also be a problem as the update is supposed to update the original program?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan All times are GMT + 1 Hour
