pip510 Regular Visitor
Joined: Oct 25, 2005 Posts: 125 Location: Sheffield South Yorks
Posted: Mon May 29, 2006 9:16 pm Post subject: Adding Poi To Tom Tom |
HI there I apoligise if this has been covered previously but i couldnt find it on the Forums.
Ok Now that the new Airport is open at Doncaster I thought I would add it to my POI for the Tom Tom.
However when I browse through my POI the airports wont show so that I can add it. (ie in as in from the location where I was, at the airport)
Now I can add it as a favourite but i really want to add it to the poi catergory not as a favourite.
Anybody got any ideas.
Thanks _________________ TomTom 300
Tom Tom 500
Let's Be Safe Out There |
alix776 Pocket GPS Moderator
Posted: Mon May 29, 2006 9:20 pm Post subject: |
just quick note ive moved it here should get more responses _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon May 29, 2006 9:29 pm Post subject: |
You can only add POI to the Custom POI that are loaded to your device, if you take a look at the POI downloads from this site you will find airports, and Doncaster is already included in the download. Mike |
Posted: Mon May 29, 2006 11:54 pm Post subject: |
thanks mike I will have a look to try and sort it out in the morning _________________ TomTom 300
Tom Tom 500
Posted: Tue May 30, 2006 12:12 am Post subject: |
I went ahead and tried that Mike it wasnt correct as the POI were all over the place I had two Poi then loaded for Manchester and Doncaster Airport both apart from each other......not by far perhaps a mile or so but still not quite right and i guess the planes landing would be a give away as to the true location but for now I dont think I will use that one as it stands at the moment _________________ TomTom 300
Tom Tom 500
BrianI Regular Visitor
Posted: Tue May 30, 2006 7:34 am Post subject: |
The problem is that you cannot modfy the POI categories that come pre-loaded in the Tomtom. The only way you can do it is to create another POI category yourself and add it in there. Unless someone knows how to modify the pre-loaded pOI categories??
Brian |
999tommo Frequent Visitor
![](modules/Forums/images/avatars/102097806847b5aca54fdd8.jpg)
Posted: Tue May 30, 2006 10:58 am Post subject: |
No, you can't modify Tom Tom pre-installed POIs. You have the facility to add custom POIs, I think it's 39 different custom groups you can add and you can have as many POIs in each group as you like (up to the memory limit of your card). To avoid the double hits, you would need to disable the pre-installed Airport POI, using Change Preferences / Manage POI / Enable Disable POI, then uncheck the Airport POI and check the installed custom Airport POI group (whatever you have called it). _________________ Tommo...
Regularly absent, but still here in spirit ! |
Thats what i did i downloaded the others from here but the airports are not in the same location! _________________ TomTom 300
Tom Tom 500
Posted: Tue May 30, 2006 11:15 am Post subject: |
This appears the only problem with downloading other peoples POI groups. As they are compiled by one person, you only have that person's view as to where the POI is. A simple error in co-ordinates can mean many miles off course. On the flip side, the speed camera POI groups from this site are continually tweaked by the staff, having received updates/additions/detetions from various members. Ideally a site with lots of POI groups, which could be managed, with input from users, would be a great idea. A bit labour intensive though and I don't think many people would want to run such a site. You could always offer ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Tommo...
Andy_P Pocket GPS Moderator
Posted: Tue May 30, 2006 1:46 pm Post subject: |
pip510 wrote: | Thats what i did i downloaded the others from here but the airports are not in the same location! |
Are you saying that the positions of the inbuilt TomTom supplied ones were better? If so, that's quite unusual! For example the inbuilt Petrol Station ones are dreadful, many missing, on the wrong side of dual carriageways, or in places that have been untouched common land for hundreds of years.
At least with a third party set, you can add any that you find are wrong: (Preferences/Manage POI/ add POI / select "GPS position" when you are at the front entrance) and remove the old one (Preferences/Manage POI/ delete POI).
The website you get it from would probably appreciate a copy of the updated file too. ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Posted: Tue May 30, 2006 3:30 pm Post subject: |
I got them from Here but it is a point to consider about editiing them though I might consider that in the future.
Also to answer your intial question yes Tom Tom POI were better than the ones from this site as they were more accurate. _________________ TomTom 300
Tom Tom 500
Posted: Tue May 30, 2006 4:30 pm Post subject: |
pip510 wrote: | Tom Tom POI were better than the ones from this site as they were more accurate. |
Over to you, PGPSW! ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Tue May 30, 2006 6:46 pm Post subject: |
pip510 wrote: | Also to answer your intial question yes Tom Tom POI were better than the ones from this site as they were more accurate. |
Anything specifically? _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Wed May 31, 2006 12:43 am Post subject: |
Oldboy wrote: | pip510 wrote: | Also to answer your intial question yes Tom Tom POI were better than the ones from this site as they were more accurate. |
Anything specifically? |
The Tom Tom ones were at the Airport the ones that have been submitted from another person on here were either a half a mile out up t a couple of miles out .
Though I did only look locally as i wouldnt normally be going to another airport further away in my own car.
Thats when Dad's Taxi service comes in too play ![Laughing Out Loud](modules/Forums/images/smiles/icon_lol.gif) _________________ TomTom 300
Tom Tom 500
Posted: Wed May 31, 2006 8:03 am Post subject: |
The Airports POI on this site was compiled in 2003. I don't know the method used in collating the data, but I know it is difficult to get accurate locations from just 1 source of information. Most are done by using the Postcode. A good starting point.
The other point is, where do you put the location point. Car Park, entrance road, middle of a runway. The choice is not always right for everyone.
I know from my own experience that even a Postcode from the 'owners' information has to be checked. As many as 10% can be either wrongly entered, or have recently been changed.
Checking, and the re-checking, is what takes up most of my time. Even then I get it wrong.;) _________________ Richard
