Pocket GPS World :: View topic - does gps data transfer baud rate matter ?
gune
PostPosted: Sun May 28, 2006 4:15 pm    Post subject: does gps data transfer baud rate matter ? Reply with quote
hi:
does gps data transfer rate matter with regards to speed of location updating etc? Question
PostPosted: Sun May 28, 2006 5:34 pm    Post subject: Reply with quote
Not really, the NMEA protocol sends very small data packets through to the PDA/ phone etc. Even at 4800 Baud it works quite well, at the higher speeds the port is left for longer with nothing to do.
The largest overhead that can delay the screen refresh is the actual redraw of the image, also enabling POI's can seriously slow the PDA down. VGA equipped devices suffer as the processor has four times the amount of work to do when compared to the more usual QVGA screens.
If you look at the NMEA sentences transmitted over a single second burst you will find its not too much in terms of data bits, you need a program to display the raw NMEA data, then look for the transmitted sentences, the text strings start with a $ symbol, then contain the Lat, long, time, date, speed, heading etc. I use my own program for doing this but it will only work with the Widcomm Bluetooth stack, any device using Microsoft (WM2005) will not work. - Mike
gune
PostPosted: Sun May 28, 2006 7:48 pm    Post subject: Reply with quote
hi mike:
so does it mean the x51 would be slower or of same speed in redrawing the map when compared with standard one like acer n35? ( even though taking in to the account of higher pocessor speed and higher rom and ram?) Rolling Eyes
PostPosted: Sun May 28, 2006 7:54 pm    Post subject: Reply with quote
It can do, it will depend how well designed the hardware is and how much spare memory the program has avail for it to use, the bigest problem in slowing the hardware down is normally down to the POI's being enabled, rather than set to "warn when near" - I wouldn't worry too much about the screen refresh rate, you only notice the slow down when comparing units next to each other, and as they are different devices/ processors etc it is an unfair comparison. The basic fact of the screen containing four times as many pixels does give the processor more work to do though - Mike
neil01
PostPosted: Sun May 28, 2006 8:08 pm    Post subject: Reply with quote
It is also worth noting, that on some equipment it is not possible to increase the baud rate - it simply will not work. The default value also being the maximum value.
philpugh
PostPosted: Thu Jun 08, 2006 5:44 pm    Post subject: Reply with quote
The speed of redraw will be impacted more by speed of the memory than the processing overhead from the serial port. In fact it could be argued that faster data rates increase processing overheads - it depends on exact implementation. What with all the other overheads going on in WM5 I wouldn't worry about it. An AXIM is more than capable of running TT5 or topo-mapping at speeds likely to be encountered on (or slightly above) :D the earth.
NMEA mandates 4800 baud as it is a marine standard for inter-operability between ship-bourne navigation aids (eg GPS, Chart Plotters, Depth Measuring etc).
SiRF (the protocol) addresses the additional capabilities of modern GPS units and, naturally, can work at higher bit rates.
Phil
