JayMann Occasional Visitor
alix776 Pocket GPS Moderator
Posted: Sun May 28, 2006 4:46 pm Post subject: |
no youll have to change to the country map in each country manually though you could use the plus map to plan a route to a destination _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun May 28, 2006 4:47 pm Post subject: |
alix776 wrote: | no youll have to change to the country map in each country manually though you could use the plus map to plan a route to a destination |
plus map ![Embarassed](modules/Forums/images/smiles/icon_redface.gif) |
Eldar Pocket GPS Moderator
Posted: Sun May 28, 2006 4:54 pm Post subject: |
JayMann wrote: | alix776 wrote: | no youll have to change to the country map in each country manually though you could use the plus map to plan a route to a destination |
A COUNTRY map + integrated Major Roads of Europe map |
Posted: Sun May 28, 2006 4:57 pm Post subject: |
Oh ok then thanks guys
so if i buy that SD card and the set of CD maps they will work ok in my TTG classic ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Sun May 28, 2006 5:10 pm Post subject: |
The alternative is the seamless "Map of Western Europe on SD card" - £179.99 |
Posted: Sun May 28, 2006 5:15 pm Post subject: |
Eldar wrote: | The alternative is the seamless "Map of Western Europe on SD card" - £179.99 |
Yeah that will be the easy way to do it but will cost about £100 more then if i buy the card and map separate |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Sun May 28, 2006 6:08 pm Post subject: |
Depends where and how you want to use the card.
I made two trips with the separate maps loaded from CD onto a big card.
First trip was along the French /Belgian battlefields , Maginot line, Luxembourg and down to near Geneva. We were near the border and crossed it several times. The map switching was a real pain and almost made the GO unusable.
Second trip was through France to Spain and back. Map was switched on entering Spain and back again a few days later on returning to France. Crossing points were known in advance and the trip planned to those points, then the map was switched. No problem at all. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Sun May 28, 2006 6:22 pm Post subject: |
I gonna be traveling from the UK to Germany
do you recommend it?? |
Posted: Sun May 28, 2006 8:01 pm Post subject: |
If you're going straight there on main roads then you should use the "plus" map of Germany from the CD set. This will give you the main roads through France and Belgium/Holland, then, when you get to Germany the map detail will increase and you will see your destination in detail. No need to switch maps.
Or you could just download the DE, AT, CH, PL and CZ map from TomTom PLUS. I believe that this map is a "plus" map. And it's only 59.95 Euros (£40). _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
PatC Regular Visitor
Joined: Apr 29, 2006 Posts: 179 Location: Reading, UK
Posted: Sun May 28, 2006 9:52 pm Post subject: |
JayMann wrote: | I gonna be traveling from the UK to Germany
Only if you really need to go there ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
julianbarker Lifetime Member
Posted: Sun May 28, 2006 10:09 pm Post subject: |
It is so easy to switch country maps, and if you travel using a plus map (which means the map includes all the major roods of Europe) then you only need to change maps to street level detail when you get near your destination. This takes about five seconds and is easy to do at a set of lights, or at a custom stop etc. I don't know why people worry about switching maps. For the record I regulalry drive in UK, France, Germany and the Low Countries and use a single plus map and the rest as non-plus maps. |
Posted: Mon May 29, 2006 10:14 am Post subject: |
These are the maps i was looking to get with a 2GB SD card ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
PatC wrote: | JayMann wrote: | I gonna be traveling from the UK to Germany
![Thumbs Up](modules/Forums/images/smiles/custom2.gif) |
