Pocket GPS World :: View topic - Think I done a hard reset????
Roy
PostPosted: Thu Nov 27, 2003 10:38 pm    Post subject: Think I done a hard reset???? Reply with quote
Rite, I turned the button which is located near the battery to off and then back on after a few hours. Now I started it up and everything that I had added had gone and it was back to normal ie like when i got it. Have I lost all my stuff as I had my poi warner on there and paid for it and is so then its gonna be hard I think getting another one the same installed because it had a spoecial number. Also everything else like pics,notes all gone
Roy
PostPosted: Thu Nov 27, 2003 11:26 pm    Post subject: Reply with quote
got the poi warner re installed now. Much say there customer service is great. Smile
happy
PostPosted: Thu Nov 27, 2003 11:32 pm    Post subject: Reply with quote
Hi ROY
I've finally done it Laughing Laughing
I did the hardware reset trick and reinstalled it all and it all works now.
Cheers .
PostPosted: Thu Nov 27, 2003 11:36 pm    Post subject: Re: Think I done a hard reset???? Reply with quote
As you've discovered, doing that resets the PocketPC to out of the box settings. Even if switched off like that for 30secs it will do the same. Normally you would only resort to that if you had an issue you were trying to resolve and all else had failed Confused
jvincuk
PostPosted: Thu Nov 27, 2003 11:45 pm    Post subject: Reply with quote
I have also learned (the hard way) about the extent of a hard reset. I have since started to use the backup tool on the program files menu.
You can backup EVERYTHING onto your mmc card so that if it comes to restoring you will get all your pictures, files, configuration etc. back. It takes a few minutes to do the backup and it's well worth it!
You may need to format your memory card though to get more space. My backup uses around 21Mb at the mo.
I have generated a custom map using the pc software which includes just the UK for now. It is around 160Mb which leaves me with +-85Mb on the card.
Smile
PostPosted: Fri Nov 28, 2003 8:05 am    Post subject: Reply with quote
Just remember to backup your storage card to PC once in a while. If your Pocket PC went walkies, then at least you would have a complete backup of it then, or even if the storage card failed.
