Pocket GPS World :: View topic - I cant load the speed cameras database
peterdubbingmixer
PostPosted: Thu May 18, 2006 9:21 pm    Post subject: I cant load the speed cameras database Reply with quote
HI there.
Ive downloaded (twice now) the speed cameras database for my Garmin streetpilot 310, and unzipped the files successfully.
When I launce the Garmin POI loader and navigate to the directory where it is stored on my C: it just isnt happening.
Has anyone got any bright ideas as this would be handy.
Peter
sherman
PostPosted: Fri May 19, 2006 1:04 pm    Post subject: Reply with quote
hello mate
have you updated the software on the 310
from the garmin site ??? using their web updater
peterdubbingmixer
PostPosted: Fri May 19, 2006 1:11 pm    Post subject: Reply with quote
thanks for your reply.
No Ive not updated the software ias it only arrived 5 days ago new, so i thought it would have the up to date software running on it.
Would this make a difference to the problem I outlined
Peter
sherman
PostPosted: Fri May 19, 2006 5:39 pm    Post subject: Reply with quote
I had a new 310 but with old software try to make a seperate folder in my documents named speed cameras or try and delete tje old Garmin POI loader and re install these are the things I did I also downloaded the speed zone database hope some of this may be of help
peterdubbingmixer
PostPosted: Mon May 22, 2006 11:24 am    Post subject: Reply with quote
Will do
Peter
NB Can you set the unit to only allow use of Motorways / main roads A and B roads?
Peter
sherman
PostPosted: Tue May 23, 2006 10:59 am    Post subject: Reply with quote
yes you can avoid motorways if you go into the navigation menu by pressing the spanner and then navigation and then avoidances
peterdubbingmixer
PostPosted: Tue May 23, 2006 11:17 am    Post subject: Reply with quote
I dont want to avois motorways. I want the unit to only allow use of main roads. The other day it took me over the moors on a very isolated road that was little more than a farmers track.
NB
Successfully upgraded the software and loaded the speed cameras database.
peter
sherman
PostPosted: Tue May 23, 2006 4:23 pm    Post subject: Reply with quote
then go in avoidances and tick all the boxes except highways and it should send you via the motorways if it is the faster or shorter route you can always touch the top banner and it will list all the turns and roads
remember on the garmins the speed camera icons only show if you are exceeding the limit but you should get a warning tone when you are near them itd normally 1000-1500 feet
peterdubbingmixer
PostPosted: Tue May 23, 2006 5:19 pm    Post subject: Reply with quote
NB this morning the Garmin with speed camera software successfully instaled gave me 2 warnings with coded references at top of screen, but no camera appeared. Any idea what is going on there?
peter
NB thanks for all your time and help
sherman
PostPosted: Wed May 24, 2006 2:42 pm    Post subject: Reply with quote
which database have you downloaded Ive used the speed zone one and its great were you exceeding the speed limit ad the camera icons only show when you exceed the limit
no probs about the help
peterdubbingmixer
PostPosted: Wed May 24, 2006 4:04 pm    Post subject: Reply with quote
Off the top of my head it was listed as a "single file" download!
Can you get rid of one for another. if so how.
Peter
22.064 (26 Jun 24)
