jvivek Occasional Visitor
Posted: Tue May 23, 2006 8:58 am Post subject: bt-338 3.11 firmware |
anyone that still has the firmware, can they please send me a pm, I just cant afford the downtime of sending the unit in to get it serviced.
Thanks |
xda Lifetime Member
Posted: Tue May 23, 2006 11:14 am Post subject: |
If you upgrade it yourself and it fails then your warranty will be void, and you would then need to send it back for repair at you own cost.
It's much better to send it back and let them do it, if they mess up it is still covered and they would replace it. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Wed May 24, 2006 12:03 am Post subject: |
I take full responsbility for my actions, I just cant afford to send it back. if it fails, I will simply buy another one but not bt-338, I wont buy globsat after they failed promises to deliver the no auto-shutdown. |
xda Lifetime Member
Posted: Wed May 24, 2006 12:01 pm Post subject: |
Each to his own, but I find the Auto Power off to be useful, saves you running the battery flat if you forget to switch it off.
With 15 hours of use from one charge there is no need to have wired in and should you be in the situation that the battery is getting low you can still plug in the in car power lead and carry on driving whilst it is charging and use your sat nav. _________________ Graham.
FlyingsCool Occasional Visitor
Posted: Thu Oct 19, 2006 10:24 pm Post subject: |
Not so simple to plug in when you are hiking. _________________ Thomas
http://www.flyingscool.com
N15802 KASH '73 Piper Cherokee Challenger 180 |
