Pocket GPS World :: View topic - TMC Aerial connection
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
depsi
PostPosted: Tue May 23, 2006 11:14 pm    Post subject: TMC Aerial connection Reply with quote
I have a Garmin TMC 12 unit which has a small aerial wire (Stub) attached to it.
Do most of you think this will be sufficient for an RDS Signal ?
Would it be possible to cut the Aerial end and attach it to a Y splitter that connect to my Aerial (i.e hard wire it to my aerial)
swing
PostPosted: Wed May 24, 2006 11:37 am    Post subject: Re: TMC Aerial connection Reply with quote
Coo, where did you get that from - I didn't think that was available yet in the UK (or maybe I should be asking where in the world are you?)
Do most of you think this will be sufficient for an RDS Signal?
Again, it depends which country you are in (your profile doesn't say). If you are in the UK (or are trying to use it in the UK) - then I suspect you are one of the first to have the GTM12, and I for one, would be interested to hear how well it works.
Not without affecting the warranty I suspect Laughing
depsi
PostPosted: Wed May 24, 2006 2:44 pm    Post subject: Reply with quote
Hi Swing,
I'm in the UK.
I manage to source one from ebay,
8) with a receipt from some shop in east London for what it's worth..
Will let you know how I get on once I've had a proper chance to use it...
Can you help me verify if it has a UK subscription.
It currently shows as RAC:Live Life time subscription but it says it's won;t get activated until I have a RDS * GPS signal. Which I don cos I can see traffic details.
I persume then it's technicaly feasible for me to directly connect it to a y splitter.
swing
PostPosted: Wed May 24, 2006 5:23 pm    Post subject: Reply with quote
This would seem to indicate is has a UK lifetime subscription (as it should)
This doesn't sound so good, I'm not sure if this is standard for the GTM units - SpeedCam / BrummyGit (or anyone else with a GTM TMC unit - did your's say something similar the first time you used it?)
Unless there's already a connector - your only option may well be to cut it as you first asked - I've no idea if it would work, but it'll definitely void your warranty (so I would ensure the unit is working first!)
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
