Pocket GPS World :: View topic - Firmware release 3.10
Goto page Previous  1, 2, 3, ... 9, 10, 11  Next
timber
PostPosted: Tue May 23, 2006 3:55 am    Post subject: Re: Firmware release 3.10 Reply with quote
This has been released today. The bug fixes don't make any mention of the problems we have experienced with 2.90 and 3.00.
Have used Firmware 3.1 for the last 3.5 hours and can report that all the previous faults are still present. Had a complete lockup that required the removal of the batteries to sort out. Back on to Beta 2.82 when i get home.
Save yourself a bit of time don't even bother to update Exclamation
prasadm
PostPosted: Tue May 23, 2006 6:43 am    Post subject: Reply with quote
3.1 correction says "Corrected a bug where MSAS test signal could cause the unit to shut down"...
Could this mean if we use GPS mode = WAAS then the unit lockup/freeze problems what most people experienced with 2.9/3.0 software will be resolved ?
It would be interesting to see feedback from someone who regularly uses WAAS mode..
greeny67
PostPosted: Tue May 23, 2006 9:59 am    Post subject: Reply with quote
Just upgraded manually to v3.1 with audio v2.3.
Have just completed a 50 mile journey in navigate mode with WAAS enabled without problems.... though in fairness I was one of the only people not to be experiencing problems with v3.0 !!!
timber
PostPosted: Tue May 23, 2006 10:02 am    Post subject: Reply with quote
Every thing you wanted to know about MSAS but were afraid to ask Exclamation
http://www.kasc.go.jp/MSAS/link4_e.html
If your any the wiser let the rest of us know Joker
PerseusTheseus
PostPosted: Tue May 23, 2006 10:14 am    Post subject: Garmin i3 Reply with quote
I have installed F/w version 3.10
I didnt have any problems with my unit unill i installed the extra voice prompts.
I previously didnt have any problems with my unit . but now ive been waiting for over 10 minuits for my unit to locate satalites ! when it used to take less than a minuit!
I have hard reset it & Re-installed F/w version 3.10 and im still waiting !
I bought my garmin unit in april 2006
Unit id = 31461232XX
came with F/w = v2.90 - No problems
Updated to = v3.00 - No problems
Updated to = v3.10 - No problems
Audio version = v2.00 - No problems
Updated Voice prompts/languages - PROBLEMS!!!
PerseusTheseus[/b]
PostPosted: Tue May 23, 2006 10:32 am    Post subject: Reply with quote
to be honest i never had any problems with 2.90... i still always get the final 200ft announcement to take the turn..
anyway, i'll get 3.10 on tonight and give it a spin.
sanaar
PostPosted: Tue May 23, 2006 10:34 am    Post subject: Reply with quote
Greeny, where did you get new audio files to download?
PerseusTheseus
PostPosted: Tue May 23, 2006 10:41 am    Post subject: Reply with quote
I too Didnt experience any problems with my i3 unit
i havnt had any trouble with any updates as-of-yet
apart from when i installed the extra language packs
... my unit has finally calmed down
it has gone back to finding satalites within a minuit and the route calulator timing seems to have been improved!
Thank Fcuk it has gone back to normal PHEW! (wiping the sweat from my head)
PerseusTheseus
waynelisa
PostPosted: Tue May 23, 2006 11:11 am    Post subject: Reply with quote
Scoobydooby wrote:
Upgrade to v3.10 done ok via webupdater, used webupdater again to and it found 3 more languages to install, so have done so.
Audio version still 2.00 Crying or Very sad
I'm not hopeful that the 2.90/3.00 bugs have been addressed as there is no mention of that in the 3.10 description, however, as I am going on a 200 mile round trip tomorrow I will be in a good position to try it out.
One hiccup & I'm going back to the very stable 2.70 that I had a while ago.
Scoobs
My audio still v2.00 Also no change there, im off out today will try 3.10 and see if any better.
richard5
PostPosted: Tue May 23, 2006 12:13 pm    Post subject: Reply with quote
Just updated to V3.10 via web updater, still ver 2 audio Crying or Very sad
Ran web updater 2 or 3 more times and downloaded all the additional languages (like i'll ever need them!) still audio ver 2!
All a bit annoying really
PerseusTheseus
PostPosted: Tue May 23, 2006 12:15 pm    Post subject: Garmin i3 Reply with quote
Did you have any problems with your unit after installing all the extra language packs as i had see above post?
PerseusTheseus
greeny67
PostPosted: Tue May 23, 2006 2:59 pm    Post subject: Reply with quote
I have never updated the audio files unless they were changed without my knowledge when I used the auto updater to install the god awful v2.9
BAVC10
PostPosted: Tue May 23, 2006 6:10 pm    Post subject: Reply with quote
Have tried 3.10 fairly extensively today and the navigation mode seems fine. On Map mode the refresh was as slow as on versions 2.9 and 3.0 but at least the dreaded blank screen never showed up. I am using 3D map and more detail level.
JinnanTonnix
PostPosted: Tue May 23, 2006 6:47 pm    Post subject: Reply with quote
I updated to 3.10 last night and had a quick bash today.
I've found some wierd faults - has anybody else got these?
1. It loves night mode. Absolutely loves it. On the way into work this morning at around 8:30am it went to night mode. However, I made another trip at around 9:10am and it changed from night mode to day mode. Yet another trip at 11:15am found the i3 changing to night mode. It's now stuck in night mode.
The colour mode is set to 'auto'. Setting it to daylight changes it, but I really want the auto function to work.
2. The time is wrong.
The time-zone is set to Europe - Western (WET) and the daylight saving is set to auto. The time is 1 hour behind. Setting the daylight saving to 'on' gives me the correct time, but surely auto should work???
I've reset the i3 several times, but no luck.
One thing I should mention is I had a total lock-up when I used version 3.0 - it went absolutely nuts, said something like 'new elevation required' (whatever that means) and went into night mode. I hope v3.0 hasn't knackered it. Is this possible?
Cheers.
colpac
PostPosted: Tue May 23, 2006 7:00 pm    Post subject: Reply with quote
downloaded 3.1 last night, after using it for 10 minutes this morning have gone back to 2.7.
In map mode all the usual screen freezes were there so i could see no point in keeping it.
Page 2 of 11
