Pocket GPS World :: View topic - StreetPilot i3 software version 3.00
Goto page Previous  1, 2, 3 ... 13, 14, 15, 16  Next
NiTrO
PostPosted: Mon May 22, 2006 4:54 pm    Post subject: i3 Unit ID number...good idea? Reply with quote
Would it help to solve any issues if we all put our Unit ID, less last 2 digits, and Software version...found in Settings...About...in this thread...together with approx date of purchase?
This will show whether it is a problem with the early versions of the i3 or not.
Mine is...
Unit ID 31461210XX
Version 2.70
January 2006
KwikSave
Coaster2
PostPosted: Mon May 22, 2006 5:05 pm    Post subject: Reply with quote
Just received this from Garmin,
Thank you for contacting Garmin Europe.
In regard to your email, it is not suggested that users revert back to
previous update versions. I would suggest resetting unit:
With the unit switched off and a fresh set of batteries please try the
following, press and hold WHEEL DOWN + BACK ARROW + ON all at the same time.
hit the power button last once the wheel down and arrow is pressed.
If the above fails then we will pass your suggestions onto our engineers, to
incorporate a remedy in future updates with more information.
Unit ID 31485110xx
Software Version 2.7
Audio Version 2.00
Purchased from Halfords in April
matb
PostPosted: Mon May 22, 2006 7:34 pm    Post subject: Reply with quote
Coaster2 wrote:
Just received this from Garmin, Thank you for contacting Garmin Europe.
excuse my language but garmin are now talking .
several of us, me included had emails from them that quite clearly stated that until a fix was made with 2.9 then we were advised to revert back to a previous f/w option.
clearly a fix was not brought about with 3.0.
my suggestion to people at the moment is if you are having problems with 2.9 or 3.0 then revert to 2.7 or 2.82. once newer versions come out then try if not happy then revert back to the one you were pleased with.
2.7 is good
2.82 gives earlier voice prompts but does not list poi's in groups only as a list nearest first.
3.10 is now available so those who wish to try please use that topic for your findings, as i know you will, because we did it for 2.9 and 3.0. likewise email garmin with your points of woe.
good luck and remember dont ask where can i get the downloads for previous f/w from they are on my sticky at the start of the forum. Wink
matb
PostPosted: Mon May 22, 2006 8:10 pm    Post subject: Reply with quote
link for i3 f/w upgrade 3.1 now on my firmware sticky
PerseusTheseus
PostPosted: Tue May 23, 2006 9:35 am    Post subject: Garmin i3 Reply with quote
I have updated to version 3.10
No problems as-of-yet
Garmin i3 bought on 26th April 2006 - Halfords Wolverhampton
Unit id = 31461232XX
Came with F/w = 2.9
Updated to F/w = 3.0
Updated to F/w = 3.10
Audio Version = 2.00
City Navigator Europe NT+ v8
PerseusTheseus[/code]
Coaster2
PostPosted: Tue May 23, 2006 2:37 pm    Post subject: Reply with quote
Just loaded 3.1. Will have a drive through town later today and report back.
Coaster2
PostPosted: Tue May 23, 2006 3:50 pm    Post subject: Reply with quote
As far as I can see, 3.1 is no different from 3.0.
Went out in map maode and the screen froze at the first major junction. Came back in Nav mode and no problems.
Back to 2.7 for me. Crying or Very sad
Coaster2
PostPosted: Tue May 23, 2006 6:19 pm    Post subject: Reply with quote
Changes made from version 3.00 to 3.10:
* Added support for Polish and Hungarian voice guidance (Requires new audio version).
* Corrected a bug where MSAS test signal could cause the unit to shut down.
Hardly going to cure the problems.
acefreecell
PostPosted: Tue May 23, 2006 9:24 pm    Post subject: Reply with quote
Out of interst Coaster, are you on eggnog stats?
I have loaded 3.10 (in the interest of testing for the user pop) on the way to work had lots of delays/lock ups, was running in 3Dmode, eggnogs on. Part way, pulled over and switched to track up, still slow to track the map (at one point I was heading off to the right?).
On the way home, I switched to standard sats and track up and got it to navigate home - I was impressed, tracked quickly and not one lock up.
Will leave as is and try map view on the way to work and see if it locks on the way.
If anyone else has loaded any version above 2.70 (the only one) then it would be helpful to see if its the eggnog or normal sats.
Acefreecell
Motorola Defy with CamerAlert, NDrive 11, Co-Pilot Live and Google Maps
formally Garmin i3, Nuvi 200 and Origin BlueI
(Origin for sale)
matb
PostPosted: Tue May 23, 2006 9:31 pm    Post subject: Reply with quote
ace my friend your input on f/w 3.1 will get lost on here (3.0)
so that all can gain from you please edit your 3.1 findings here
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=40581
thanks Wink
acefreecell
PostPosted: Tue May 23, 2006 10:11 pm    Post subject: Reply with quote
Cheers matb, copied to v3.1 thread.
Acefreecell
(Origin for sale)
wherethehellarewe
PostPosted: Tue Jun 20, 2006 1:55 pm    Post subject: Reply with quote
Hi All,
Got my i3 last Friday it was on firmware version 3.0 and audio 2.5 straight out of the box. Initial satellite lock time was around 3 minutes and to be honest I cant fault the thing. Turn warnings are accurate and well timed, the map is where I am at all times whether Im in navigate or map mode. I have experimented with eggnos and GPS and I can't say that I've noticed a significant difference between them. I for one am very pleased with the unit although I have nothing to compare my experiences with as I havent tried any of the previous firmware versions.
Jus my tuppence worth Laughing
Ignorance is no excuse !
Ridgeback
PostPosted: Wed Jul 26, 2006 4:48 pm    Post subject: Reply with quote
Has anyone loaded StreetPilot i3 Ver. 3.10 as of May 19, 2006 ??
I don't really want to upload it to my i3 until I know it works. Confused
Ta muchly
bennnneb
PostPosted: Wed Jul 26, 2006 8:02 pm    Post subject: Reply with quote
i have got an i3 with the maps stored internally.can anybody explain why i can navigate to european cities in firmware 3.10 but not 2.70?which firmware introduced all the european cities?
darrah
PostPosted: Wed Aug 02, 2006 6:54 pm    Post subject: Reply with quote
Had a Garmin i3 street pilot for a while and am happy with it.Recently however I have come across a couple of routes in the wilds of Lincolnshire where turn offs haven't existed or been dead ends.Also in Lincoln city centre I was directed to go the wrong way up a one way street.
My question is
Is it possible to download updated maps and if so how?
Page 14 of 16
22.123 (18 Dec 24)
