Posted: Mon May 01, 2006 6:37 pm Post subject: Cannot reload map after powering off
I'm using R66 Navigate7, which I think on the whole is very good, but there is one small problem that I thought someone might have a solution to.
When it's navigating to a destination, if I power off the pocketpc, and then later power it back on, it picks up the gps signal again, and shows the route, but the rest of the map is not loaded up, which means that if I make a wrong turn, it shows my position in a sort of "no-man's land", with no streets marked apat from the route. It also cannot correct mistakes and calculate the new route.
This is not a huge issue, but it would be useful to be able to turn off the ppc to conserve battery power for example if part of the route has a long motorway component with no turns.
Posted: Mon May 22, 2006 4:55 pm Post subject:
Get a car charger cable to ensure the device remains charged and powered up while in the car, turning the device off is not a good idea as you will not get speed camera alerts while the unit is sleeping - Mike
