SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Sun May 21, 2006 8:52 pm Post subject: Nuvi - How To Set Location.... |
Has anyone found a way of setting your location using a postcode or address, with the GPS switched off.
I thought if I was to select 'Where to?' and enter the postcode, instead of selecting the Go! icon I select 'Show Map' I would see the 'Set Loc.' icon but no. |
cantgetlost Frequent Visitor
Posted: Sun May 21, 2006 9:49 pm Post subject: |
Not sure if this is what you want! But you can drag the map with the address under the small white arrow tap sat location and you are done. Or view an adress on the map and do the same! |
Posted: Mon May 22, 2006 2:08 pm Post subject: |
You can find a location with GPS off set t to navigate and when its calculated zoom out arrow in on the address and set as location if that makes sense ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Mon May 22, 2006 8:08 pm Post subject: |
Thanks for the replies, the zooming in & out is the method I've been using, but the Where To and then Show Map seems so logical, they just need to add the Set Loc. button. |
