Pocket GPS World :: View topic - IPAQ 1940 + Tom Tom 5 COM Port Problem
ukjag
PostPosted: Sat May 20, 2006 3:28 pm    Post subject: IPAQ 1940 + Tom Tom 5 COM Port Problem Reply with quote
I'm in the process of trying to set up my IPAQ 1940 and GPS connection. The instructions say the GPS settings should be set to Baud Rate: 19200 and COM Port 1.
I go into the software and select the following:
Show GPS Status
(Have to select one of the following:
Tom Tom Wireless GPS
Tom Tom Cable GPS
Other Bluetooth GPS
Other Cable NMEA GPS)
I select Other Cable NMEA GPS (I presume this is correct)
Select the Baud Rate of 19200
I then get a screen asking saying "GPS is connected to:
COM3
Bluetooth Serial Port...
S2410 IRDA2410
S2410 COM0
Serial on USB
As you can see there isn't an option to select COM1. I have tried COM3 but doesn't work.
I have turned the Beam off under Settings, Connections on the IPAQ. I have no idea how to check what COM Ports are being utilised on the IPAQ.
Anyone have any ideas how to get COM1 working?
Many thanks,
Ian
Grace0803
PostPosted: Sat May 20, 2006 4:07 pm    Post subject: Reply with quote
I presume its a wired GPS? If so try using the TomTom cable GPS option instead of NMEA. It may take a minute or two to pick up the Sats. If the small yellow circle starts spinning you are sorted.
ukjag
PostPosted: Sat May 20, 2006 4:58 pm    Post subject: Reply with quote
Yes it is, via a USB to Serial power/data cable. Have tried the TomTom GPS option and still no joy, yellow circle motionless.
I know the com port 1 works as I can use active sync without any issues, could it be that the supplied usb to serial cable is a bit dodgy and not communication between the pda and receiver?
Thanks,
Ian
alix776
PostPosted: Sat May 20, 2006 6:39 pm    Post subject: Reply with quote
have you unchecked the recieve all incoming beams in the connections menu
device Lumia 950 xl
ukjag
PostPosted: Sat May 20, 2006 6:59 pm    Post subject: Reply with quote
Yeah. In the corner of the GPS screen, the blue/yellow quadrant circle is totally motionless, absolutely no indication that it's even trying to connect.
Thanks,
Ian
PostPosted: Sat May 20, 2006 7:02 pm    Post subject: Reply with quote
A little more information might help, firstly which version of TomTom are you using (to find this tap the sat strength meter on the main nav screen) is it 5,00 or 5,1 or 5,21 secondly which GPS unit are you tryi to get working make and model number please - Mike
ukjag
PostPosted: Sun May 21, 2006 8:53 pm    Post subject: Reply with quote
Hi Mike,
Using Version 5.000 (4890)
Arkon Powered PDA Mount with Integrated GPS
Many thanks,
Ian
PostPosted: Sun May 21, 2006 9:12 pm    Post subject: Reply with quote
First off try updating the TomTom install to the latest version TTN5,21 its free from www.tomtom.com then try the GPS set-up again. As a real long shot is there any external keyboard software loaded onto the device, or any other peripheral control software that takes over the serial port? the reason I ask is the external keyboard application needs to be selected to IrDA/ Com1 or Keyboard on some devices - Mike
tbarnes520
PostPosted: Sun May 21, 2006 11:13 pm    Post subject: Reply with quote
I had the same problem with an Arkon mount which I solved by selecting TomTom Wired GPS, it also woked on NMEA with a lower Baud rate.
I hope this is of some help to you.
PS: Be patient the first time it seems to take forever to get a fix!
Tom
Tomtom Navigator 5 on a HP Ipaq HX4700, Mio 268, TT3 on Ipaq 5555, and a host of others.
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
ukjag
PostPosted: Mon May 22, 2006 6:37 pm    Post subject: Reply with quote
Hi there,
Did you get any clue that it picked up the GPS unit but was just slow picking up a signal? The reason I ask is that as soon as I select either the TT Wired or NMEA it just says GPS Not Found.
Thanks,
Ian
tbarnes520
PostPosted: Mon May 22, 2006 6:45 pm    Post subject: Reply with quote
When I get home tonight I will fish it out and try it, I have since stopped using it but it is still in the house. If I do not reply tonight it will be sometime tomorrow.
Take care.
Tom
23.011 (02 Jan 25)
