Pocket GPS World :: View topic - setting time
setting time
kevinburton
PostPosted: Wed May 17, 2006 6:42 pm    Post subject: setting time Reply with quote
how do you set the time on navman 510 please
nortonbeak
PostPosted: Wed May 17, 2006 7:32 pm    Post subject: Reply with quote
I believe you have to accept the time of day from the satellite. I don't think that the ICN 5xx has an internal clock
Navman ICN 520
512 Mb Cygnet SD card
Smart ST 2005 + SP 1
Tim Buxton
PostPosted: Wed May 17, 2006 7:41 pm    Post subject: Reply with quote
But you can alter the hour offset under Preferences, More Preferences, Measurements.
Tim
kevinburton
PostPosted: Sun May 21, 2006 6:13 pm    Post subject: Reply with quote
there must be a way to set the time somehow.
Tim Buxton
PostPosted: Sun May 21, 2006 6:17 pm    Post subject: Reply with quote
The time comes from the GPS. Is yours not setting?
Tim
kevinburton
PostPosted: Sun May 21, 2006 6:20 pm    Post subject: Reply with quote
it is showing time but for some reason it is not correct time.it used to be correct then for some reason it is now not correct
Tim Buxton
PostPosted: Sun May 21, 2006 6:21 pm    Post subject: Reply with quote
Are the minutes still correct?
Tim
kevinburton
PostPosted: Sun May 21, 2006 6:23 pm    Post subject: Reply with quote
no minutes are incorrect but hour is ok
Gee-Pee
PostPosted: Sun May 21, 2006 7:43 pm    Post subject: Reply with quote
Just a thought - are you checking the clock while you have GPS acquisition Question
Gee-Pee
kevinburton
PostPosted: Sun May 21, 2006 7:46 pm    Post subject: Reply with quote
same outcome whether i have a gps signal or not.this is a new unit 3 months ago which was changed under warranty for defective previous unit but warranty is now not valid.
Gee-Pee
PostPosted: Sun May 21, 2006 7:53 pm    Post subject: Reply with quote
If the unit is only 3 months old, I would have thought you still have recourse to the seller. Try asking them to check the time setting - if that's possible and if they can't do it ask for a replacement.
Gee-Pee
kevinburton
PostPosted: Sun May 21, 2006 7:54 pm    Post subject: Reply with quote
the unit was a replacement direct from navman.it was ok then went kaput.
Tim Buxton
PostPosted: Sun May 21, 2006 7:56 pm    Post subject: Reply with quote
Just to narrow it down some more, do you have a route set and from which page (map screen or Measurements) are you reading the time?
Tim
kevinburton
PostPosted: Sun May 21, 2006 8:01 pm    Post subject: Reply with quote
time is incorrect with route in or not.reading time from bottom of screen when unit is on if that is what you mean.i think i will email navman to see what they say .
Tim Buxton
PostPosted: Sun May 21, 2006 8:17 pm    Post subject: Reply with quote
Can you see what the time says on the Measurements page, to the right of the Offset time?
Tim
22.064 (26 Jun 24)
