Pocket GPS World :: View topic - StreetPilot i3 software version 3.00
Goto page Previous  1, 2, 3 ... 12, 13, 14, 15, 16  Next
devon-surfer
PostPosted: Mon May 22, 2006 10:42 am    Post subject: Reply with quote
Ihave now put beta 2.82 on mine, following in the footsteps of matb. Fe up with the time it takes for the screen to refresh etc on version 2.9
Dilcymro
PostPosted: Mon May 22, 2006 11:26 am    Post subject: Reply with quote
morning all,
I have decided to install beta 2.8 from the downloads in Matb`s sticky also. I found the other day whilst using ver 3.0 that the voice commands were comming much too early when navigating which resulted in my taking a left or right turn before the one the i3 wanted me to take, resulting in gladys shouting re-calculating and then that I had reached my destination on the left when there was nothing there, the house was on the right . So we shall give it a go, if it `s no good will revert back to ver 2.7 but going by the oracles on these boards most seem to stick with ver 2.8 beta.
Regards.....Dil
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
PerseusTheseus
PostPosted: Mon May 22, 2006 11:32 am    Post subject: Garmin i3 Reply with quote
I still cant get my head around why there are so many people having problems with the i3
My unit is fairly new and came with version 2.9 F/w 2.0 Audio & V8 maps
I have uploaded version 3.0 F/w , Speed cam database and around 50k POI's
when not navigating a have it in map mode
when navigating i have it in 3d mode
On cold startup it takes around 30 seconds to find satalites
It has never locked up or frozen
It has never let me down yet
As this is the only unit type i have ever owned i seriously doubt i will ever have another unit :D
PerseusTheseus
Coaster2
PostPosted: Mon May 22, 2006 11:38 am    Post subject: Reply with quote
I'm now using 2.8 and have no problems at all.
Lester_Burnham
PostPosted: Mon May 22, 2006 11:45 am    Post subject: Re: Garmin i3 Reply with quote
PerseusTheseus wrote:
I still cant get my head around why there are so many people having problems with the i3.
Because quite patently, there are some software problems with the later versions of firmware.
Lester_Burnham
PostPosted: Mon May 22, 2006 11:46 am    Post subject: Reply with quote
2.8?
Didn't know that was released.
Do you mean the beta version 2.82?
Dilcymro
PostPosted: Mon May 22, 2006 11:56 am    Post subject: Reply with quote
My apolagies, have now installed ver 2.82 beta ( to be more specific )
Regards....Dil
PerseusTheseus
PostPosted: Mon May 22, 2006 12:01 pm    Post subject: Re: Garmin i3 Reply with quote
Well then, wouldnt those problems be corrected with an upload of the newer firmware versions, Looking at this thread it certainly isnt the case.
PerseusTheseus
Coaster2
PostPosted: Mon May 22, 2006 12:07 pm    Post subject: Reply with quote
2.8?
Sorry, missed the two off.
Lester_Burnham
PostPosted: Mon May 22, 2006 12:54 pm    Post subject: Re: Garmin i3 Reply with quote
PerseusTheseus
??? Haven't you just contradicted yourself with that paragraph?
And have you actually fully read the threads on this?
v2.70 was actually generally well received - no obvious issues.
However, the beta 2.82 introduced some improvements that some benefitted from, and did introduce a minor bug, that was corrected with v2.90.
However, v2.90 also seemed to introduce a whole deal of stability problems. As did v3.00.
So options are:-
1. Live with it.
2. Revert to v2.70, and live without the improvements - for some that's actually a benefit.
3. Revert to 2.82 as it had some benefits, and only a minor downside (custom POIs not categorised, so only 50 near your current location).
Your tone in reply to this thread, almost sounds like people have courted stability issues. However, it can tend to be a balance between wanting some improvements in later firmware, and in the case of 2.90 and 3.00 living with compromises to the unit's stability and performance.
trevf
PostPosted: Mon May 22, 2006 1:37 pm    Post subject: Re: Garmin i3 Reply with quote
PerseusTheseus
So options are:-
1. Live with it.
Lester. Surely an upgrade should be just that, a move up, not a move where something is improved at the cost of the main function of the device... I can install FW3 wich should be the best FW and my i3 will now speak fluent Outer Mongolian (obviously a major benefit) but on the downside it now produces rubish routes, does not update the screen correctly and crashes at random. I would not call these comprimises, more screw ups!
Garmin i3
Firmware 3.4
Lester_Burnham
PostPosted: Mon May 22, 2006 2:25 pm    Post subject: Re: Garmin i3 Reply with quote
(shrug) like I care...
I'm not defending Garmin, or each version of the firmware.
I've merely pointed out why people are using various versions, and pointing out that the numbers of feedback, here, for versions 2.90 and 3.00 do point to their actually being true software issues with these versions, and not something merely in the minds of the complaining users.
And?
I'm not defending the versions, or that they should be improvements. Merely why people may be using them. FWIW, I'm using v3.00 and am far from happy with it. In recent times, I'd say I found 2.82 the version I was most happy with. However, the stability, freezing and update issues I've had since, have been true faults, just not so inconvenient that I've been that bothered about reverting to 2.82 or 2.70.
That there are faults with them, and this is not merely figments of users' imaginations was my point in contributing to this thread.
PerseusTheseus
PostPosted: Mon May 22, 2006 4:01 pm    Post subject: Re: Garmin i3 Reply with quote
And?
PerseusTheseus
PostPosted: Mon May 22, 2006 4:10 pm    Post subject: Garmin i3 Reply with quote
I was wondering weither these faults that you all seem to be experiencing could be down to "older units" (hardware)
Glitches in newer sofware could make these faults more apparent
My best friend has jumped on the i3 bandwaggon since spotting mine in my car, I have uploaded the v3.0 f/w and custom POI's for him and as of yet he has had no problems or experienced any faults which you seem to mention.
Has any one who has bought a brand new i3 within the past month experianced any problems with Units that have had v2.9 or 3.0 already preinstalled ?
Coaster2
PostPosted: Mon May 22, 2006 4:45 pm    Post subject: Reply with quote
My mistake. Screen froze twice today, once in Nav mode and once in map mode. Back to 2.7 again. Crying or Very sad
Page 13 of 16
22.123 (18 Dec 24)
