xp Occasional Visitor
Posted: Tue May 16, 2006 12:57 am Post subject: audio |
Do you know if the tomtom 910 has a audio out put for a extension speaker.
Les |
Posted: Tue May 16, 2006 4:18 am Post subject: |
No it does not, the audio output is intended to go into the Stereo for amplification before playing through the speakers, the inbuilt speaker is actually very good itself, but limitted to mono - I always go with the external feed into the cars Kenwood system - Mike |
Andy_P Pocket GPS Moderator
Posted: Tue May 16, 2006 11:34 am Post subject: |
Or you can buy an amplified external speaker |
Posted: Tue May 16, 2006 7:04 pm Post subject: External speaker |
Hi Andy
Where world you plug the external speaker in to if there is no speaker out put.
Les |
Posted: Tue May 16, 2006 7:11 pm Post subject: |
An amplified speaker (the same type you have on your PC) will connect to the Go-910 car mount and it will then work just fine, its a shame the home mount is missing this feature, as I feel it would be worth while - still you can't have everything - Mike |
Posted: Tue May 16, 2006 7:17 pm Post subject: Speaker |
Thanks for all the info mike
Les |
Posted: Wed May 17, 2006 12:07 am Post subject: |
xp-
The Go910 does not have a "speaker" output i.e. an output with enough power to drive a loudspeaker.
It does have a "line" output, i.e. an output similar to the phono outputs on a C.D. player, which is suitable to feed power amplifier which in turn feeds a loudspeaker.
A "powered (or amplified) loudspeaker" is simply a power amplifier and a loudspeaker in the same box. Examples are the speakers attached to most PCs, or the little speaker systems sold for Walkmans and iPods. One of these, either battery powered or capable of being run from the 12 Volt car supply,, would work fine with the Go910. |
Gerco Occasional Visitor
Posted: Fri May 19, 2006 8:03 pm Post subject: |
Check here
[http://www.fastmute.de/vers02_engl/index2.php?id=&parent=&versendet=]
Much better with more power and more features.
Designed for any car radio.
You get your voice commands highly amplified (10 W) out of your car speakers.
Ultra fast switching mute generator.
Gerco |
JockTamsonsBairn Lifetime Member
Posted: Sat May 20, 2006 1:20 am Post subject: |
Gerco wrote: | Check here
Gerco |
Code: | [url=http://www.fastmute.de/vers02_engl/index2.php?id=&parent=&versendet=]here[/url] | here _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Sun May 21, 2006 6:21 pm Post subject: |
Why is the additional device required? If you load the mp3 to the GO-910 it will automatically perform the function of switching between music, navigation and alert warnings. All you need to make sure is you can get the audio output from the Go device into the car system. Mike |
