Pocket GPS World :: View topic - Tom Tom GO 700 phone volume
tomtomg0700
PostPosted: Fri May 19, 2006 9:30 am    Post subject: Tom Tom GO 700 phone volume Reply with quote
Does anybody know how to increase the blue tooth phone volume as its quiet on my Tom Tom 700
The actual main Tom Tom volume makes no difference to the phone settings and is too quiet on the move, any ideas ?
Im using it with a Nokia phone
Spark1e
Banned
PostPosted: Fri May 19, 2006 9:38 pm    Post subject: Reply with quote
While you are making a phone call touch your screen to go to menu & then go to your phone icon & press again - you'll see a new menu appear :D .
tomtomg0700
PostPosted: Sat May 20, 2006 9:52 am    Post subject: Reply with quote
Cheers problem sorted !!
mmman
PostPosted: Sat May 20, 2006 5:41 pm    Post subject: Reply with quote
Hey cheers Spark1e, never knew that! :D
PatC
PostPosted: Sat May 20, 2006 7:18 pm    Post subject: Reply with quote
On the x10 (not sure about other nodels) you can also adjust the phone volume with the slider control, as you would the voice navigation volume. The two volume settings are independent of each other.
TomDavison
PostPosted: Sun May 21, 2006 10:08 am    Post subject: Reply with quote
Excellent answer. I didn't know that, and for the last 5 months I've not been using hands free, because the volume was too low.
PatC
PostPosted: Sun May 21, 2006 10:27 am    Post subject: Reply with quote
I think the manual could be a lot better as I don't recall either of these phone volume options being mentioned.
Also, when I click on the phone audio icon in the menu referred to above, the phone disconnects from the 510 every time. I assume this is another quirk with Sony Ericsson phones, as with not sending the caller ID to the TT.
mmman
PostPosted: Sun May 21, 2006 2:40 pm    Post subject: Reply with quote
The 'manual' could be a lot better in many ways Wink
Another 'quirk' of Hands-free is that although BlueTooth apparently drains the phone's batteries pretty quickly, which means you have to keep the 'phone charged up, the TomTom's mic will only work if you have it plugged into the lighter socket... Rolling Eyes
TomDavison
PostPosted: Sun May 21, 2006 3:45 pm    Post subject: Reply with quote
Surely that's because the mic is part of the mount, which has no battery, and is only powered by the aux power plug. As far as I know, the Go itself doesn't feed power back down into the mount to run the mic.
PatC
PostPosted: Sun May 21, 2006 8:49 pm    Post subject: Reply with quote
Really? Well that may explain why I keep being told about the poor performance of the handsfree from people I'm speaking to. I only connect to the lighter socket when the battery is running low.
mmman
PostPosted: Sun May 21, 2006 11:14 pm    Post subject: Reply with quote
Quite possibly, but whatever the reason, it's a bit dumb...
23.054 (28 May 25)
