Pocket GPS World :: View topic - Favs to POIs?
Favs to POIs?
BoldBelvoir
PostPosted: Wed May 17, 2006 7:10 pm    Post subject: Favs to POIs? Reply with quote
Is there a way I can turn Favourites into POIs from within TT5.21 without using any TPI software?
Oldboy
PostPosted: Wed May 17, 2006 7:28 pm    Post subject: Reply with quote
Yes.
In Manage POI you need to create a new POI category. Give it a name and select a bitmap.
In Browse Map, Find, Favourite, select your first entry. The map cursor will display the location.
Then tap the Cursor Icon at the bottom of screen, and select Add as POI, select your new category. If you want to keep the original text just press Done.
Do the same for all your Favourites.
You now have a POI of all your Favourites, which you can add even more to, and transfer from Device to Device and, more importantly, Backup.;)
BoldBelvoir
PostPosted: Thu May 18, 2006 11:15 am    Post subject: Reply with quote
Thanks for that. Seems rather long-winded, but it works!
Phil.
wazzzzupmate
PostPosted: Thu May 18, 2006 11:45 am    Post subject: Reply with quote
Seems long winded, but you will be glad you have done it when your pda loses its favourites.
junger
PostPosted: Sun May 21, 2006 10:32 pm    Post subject: bitmap Reply with quote
hi
just reaing the tread, i have put my bitmap and the binary in the gb folder like the other poi' s but i cannot access them in the mio any ideas please
Oldboy
PostPosted: Sun May 21, 2006 11:04 pm    Post subject: Re: bitmap Reply with quote
junger wrote:
hi
There is a limit of how many Categories TomTom will recognise. I believe it is 39 in TTN5.
Have you exceeded this limit?
junger
PostPosted: Mon May 22, 2006 12:05 am    Post subject: Reply with quote
thanks for the reply
no, i dont think i have, there are 15 active pio' s, the rest are not ticked
thanks
Oldboy
PostPosted: Mon May 22, 2006 7:14 am    Post subject: Reply with quote
thanks
It's not the number of ticked POI's that are counted, but the total number loaded on the Device.
It is the number that you add yourself to check. Don't count those that are pre-installed.;)
junger
PostPosted: Mon May 22, 2006 12:30 pm    Post subject: Reply with quote
i can pick a basic icon, but cant get it to apply mt bitmap, could it be the size of the bitmap
wazzzzupmate
PostPosted: Mon May 22, 2006 12:40 pm    Post subject: Reply with quote
your bitmap needs to be 22 x 22 pixels
junger
PostPosted: Mon May 22, 2006 8:38 pm    Post subject: Reply with quote
hi again
thanks for the info, works a treat.can i add phone numbers to the data acssociated with the information of the pio?
many thanks
junger
PostPosted: Mon May 22, 2006 9:29 pm    Post subject: Reply with quote
its ok , ive worked it out thanks
cirrus363
PostPosted: Wed Jun 07, 2006 2:18 pm    Post subject: Reply with quote
Hi Junger
I was interested in adding phone numbers to my POI's can you give a little guidance for an absolute beginner?
22.064 (26 Jun 24)
