Pocket GPS World :: View topic - Can the default speed be changed in TTN5?
yesman72
PostPosted: Tue May 16, 2006 3:24 pm    Post subject: Can the default speed be changed in TTN5? Reply with quote
When a routeplan is done, the default speed limits is used to calculate time for travel. Can these be changed as in TTN 3?
/Mike
Silav101
PostPosted: Tue May 16, 2006 5:12 pm    Post subject: Reply with quote
Nope.
MarkHewitt
PostPosted: Wed May 17, 2006 3:01 pm    Post subject: Reply with quote
Actually that should be yes! Go into the preferences menu and look for road speeds, you can configure it from there.
From TomTom4 onwards this feature was removed.
lupos0_1
PostPosted: Wed May 17, 2006 4:06 pm    Post subject: Reply with quote
As the question was directed for TT5, the answer remains NO
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
alix776
PostPosted: Wed May 17, 2006 7:20 pm    Post subject: Reply with quote
actually the answer is yes using the limited speed option if you set the speed to say 50 mph then the eta will change as tt5 caluculates that can not acheive a spped of over 50mph so the roads speeds have changed Wink
device Lumia 950 xl
Silav101
PostPosted: Wed May 17, 2006 9:32 pm    Post subject: Reply with quote
- pokes Alix -
Ah, but he asked if you could _change_ the speeds, not use a limited speed to manipulate the route; also the result of that routing would be different if one could manually alter the default speeds. :-)
Po-taytoe, poh-tahtoe.
22.101 (03 Oct 24)
