chris_w Pocket GPS Verifier
Joined: Nov 09, 2004 Posts: 628 Location: West Yorkshire
Posted: Mon May 15, 2006 2:09 pm Post subject: A couple of Nuvi 350 Questions |
I have some questions about the Nuvi 350 I'm hoping somebody can help me with.
1. Can you turn "lock to roads" off like on the GPSV and 76s and use it as a handheld?
2. Does it automatically change to "night mode"?
3. Are there any TMC options for the unit?
Thanks for your help. _________________ Thanks,
Chris |
Posted: Tue May 16, 2006 12:15 pm Post subject: |
Bumping.... Anyone? _________________ Thanks,
Chris |
Superten Occasional Visitor
Posted: Tue May 16, 2006 12:40 pm Post subject: |
1) You can select OFF ROAD if thats any good
2) Yes it does
3) If TMC is something to do with Traffic, you can buy an add on I think
cheers |
Posted: Tue May 16, 2006 2:05 pm Post subject: |
Thanks Superten!!!!!
Does OFF ROAD plot a straight line to your destination without providing route instructions etc..? _________________ Thanks,
Chris |
PatC Regular Visitor
Joined: Apr 29, 2006 Posts: 179 Location: Reading, UK
Posted: Tue May 16, 2006 2:08 pm Post subject: |
chris_w wrote: | Does OFF ROAD plot a straight line to your destination without providing route instructions etc..? |
Surely if it did you could manage with just a compass? |
Posted: Tue May 16, 2006 2:14 pm Post subject: |
PatC wrote: | chris_w wrote: | Does OFF ROAD plot a straight line to your destination without providing route instructions etc..? |
For what I'm using it for - nope.
Unless compasses can find Geocaches now. _________________ Thanks,
Chris |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Tue May 16, 2006 5:43 pm Post subject: Re: A couple of Nuvi 350 Questions |
chris_w wrote: | 3. Are there any TMC options for the unit? | Yes, the GTM10, GTM11 or the GTM12 - if you check www.garmin.com/products/nuvi or Nuvi Accessories you'll see the options, although I'll note the GTM12 is not yet available. If you are buying online for use in the UK, make sure you buy a UK model, which includes a lifetime subscription to the Trafficmaster RDS-TMC service (not included on the US or European versions). |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Tue May 16, 2006 5:54 pm Post subject: |
but having a gps sytem means you don't need to mess about with a map to work out where you are... hence no need for maps and compasses! |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue May 16, 2006 6:35 pm Post subject: |
PatC wrote: | Surely if it did you could manage with just a compass? |
Why would you want a compas when you can use a sextant? _________________ Gone fishing! |
Posted: Tue May 16, 2006 7:19 pm Post subject: |
Skippy wrote: | PatC wrote: | Surely if it did you could manage with just a compass? |
Why would you want a compas when you can use a sextant? |
True; this newfangled compass technology will never catch on.
PS - I've never understood why they don't bend the needle a bit to point true north |
Posted: Tue May 16, 2006 7:25 pm Post subject: |
PatC wrote: | Skippy wrote: | PatC wrote: | Surely if it did you could manage with just a compass? |
Tried seaweed as well but the damn stuff just won't stay striaght
Thanks for all your replies - There's a very good chance I'm going to go for one of these babys instead of another TT
I miss my Garmin units they were much better built and the SW was much more stable. _________________ Thanks,
Chris |
SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Wed May 17, 2006 11:02 pm Post subject: |
Well having used TomTom products since v1, I've now switched back to Garmin.
If it helps I've had my Nuvi 350 & GTM-11 for about 3 hours now, and I'm impressed with the TMC traffic, working perfectly in my hotel room. Will report more tomorrow after my drive home.
For info, I purchased it from ASK, Tottenham Court Rd, £500 for both the Nuvi & TMC.
Also the Garmin routing is better than the new & old TomTom units. This is based on my usage of the i3 |
Posted: Thu May 18, 2006 12:46 am Post subject: |
SpeedCam wrote: | Well having used TomTom products since v1, I've now switched back to Garmin.
Could you please explain to me how the GTM-11 'fits in' to the car - i.e. does it need a cigarette lighter feed, does it connect to the car arial or have it's own antenna - and is this internal or external? I'm just wondering how clean or messy the configuration is in terms of having wires all over the place.
Another thing I've never been able to establish - does the 350/360 pronounce e.g. A4133 as you would expect, or as "A four thousand one hundred and thirty three" as I believe the TT 910 does?
I'm very interested to hear more after you have used this setup for a while. |
Posted: Thu May 18, 2006 8:43 am Post subject: |
PatC wrote: | Could you please explain to me how the GTM-11 'fits in' to the car - i.e. does it need a cigarette lighter feed, does it connect to the car arial or have it's own antenna - and is this internal or external? | It takes power from the Nuvi itself - and you have to have the Nuvi powered for it to work - ie you cannot run the Nuvi and the GTM-11 off the Nuvi's batteries. The power has to use the car cradle connector, and the GTM-11 plugs into the side USB socket on the Nuvi.
The GTM-11 uses an external aerial, 2 of which are provided - a 10" solid aerial, and a long t-shaped wire antenna. With a y-splitter cable, it could be feed directly from the car aerial, although if you are considering permanently mounting it and connecting it to the car aerial, the GTM-10 may be better, as it's designed for this.
If you read the GTM-11 manual, available from here it might help you - it certainly shows the unit with the 10" whip aerial fitted.
I'll let SpeedCam answer on the TTS question, but given Garmin have been providing TTS for a while, and update their voices to deal with mapping data anomalies, I would hope this was handled correctly. |
Posted: Thu May 18, 2006 12:55 pm Post subject: |
swing wrote: | If you read the GTM-11 manual, available from here it might help you - it certainly shows the unit with the 10" whip aerial fitted.
Thanks - for some reason it never occurred to me to look for an online manual. That does make it much clearer though. I had assumed for some reason that the aerial has to be mounted outside the car, but it seems not. |
