Pocket GPS World :: View topic - TomTom announce the New range of GO devices one week before
Goto page Previous  1, 2, 3 ... 21, 22, 23
jean
PostPosted: Tue May 16, 2006 9:43 am    Post subject: Reply with quote
I have the bell for my cameras and we love the loud 'boingggg' that we get - it certainly keeps you on your toes Laughing Out Loud!
PostPosted: Tue May 16, 2006 10:44 am    Post subject: Reply with quote
You will only get the text to speach spoken alerts IF you use a computer voice, also the options for setting up the spoken text must be performed via the Go-910 screen, if you use the TomTom Home software you will not see the options to enter the text (probably as the home software is generic and can be used across different devices), so the "extras" within the 910 are not covered.
I loaded the POICapture utility onto my 910 the other week, it will capture a location BUT it fails to add the POI, so there is nothing stored within the POI file, however there is a text file that is generated, this contains the correct information, but it means you must pull the file off the GO-910 each time you dock the device. Then edit the text file in note pad to obtain the data, Lutz is aware of this issue - Mike
jkrabbel
PostPosted: Wed Jul 12, 2006 12:52 am    Post subject: TOM TOM is a NO NO Reply with quote
I've owned this product a mere two weeks and after just 2 uses it fell apart. The screen froze and couldn't be turned off, causing it to overheat which than caused the screen to crack when touched. To make matters worse the company refused to replace or fix a clearly defective model and wanted to charge an ADDITIONAL $500 to fix. So if you've got the money to throw away and want to invest in a product that even its own producers won't stand by, by all means purchase it.
PostPosted: Wed Jul 12, 2006 4:45 am    Post subject: Re: TOM TOM is a NO NO Reply with quote
I find that a little hard to believe..... Confused
charliejopling
PostPosted: Sat Jul 15, 2006 11:45 pm    Post subject: Reply with quote
I am considering buy the 510, but have heard bad things about the power connection when using the mount. Is this a problem that any of you have experienced, and should I be worried?
charlie
PostPosted: Sun Jul 16, 2006 3:50 pm    Post subject: Reply with quote
On some mounts the vibration causes a momentary loss of power, which causes the unit to switch off as it thinks the ignition has been turned off. This has been "cured" in the latest software by simply removing the auto-power-off feature.
No *personal* experience. Still perfectly happy with my Go300 Smile (though new maps would be nice!).
charliejopling
PostPosted: Sun Jul 16, 2006 11:49 pm    Post subject: Reply with quote
cheers matey, you're a star.
charlie
smiley1081
PostPosted: Sat Oct 14, 2006 8:33 pm    Post subject: Continental differences.. Reply with quote
BTW, are there differences between a TomTom 910 sold in Europe and one sold in the USA?
Having a brother in California, the difference between $584 and 699 EUR is tempting...
PostPosted: Sat Oct 14, 2006 9:34 pm    Post subject: Reply with quote
The devices should be identical.
tgold
PostPosted: Sat Oct 14, 2006 9:38 pm    Post subject: Re: Continental differences.. Reply with quote
The UK model: http://www.tomtom.com/products/section.php?ID=212&Section=338&Category=0&Lid=1 and USA model: http://www.tomtom.com/products/section.php?ID=268&Section=339&Category=0&Lid=4 appear to be totally identical in maps, specifications and what is included inside the product box.
Tony
smiley1081
PostPosted: Sun Oct 15, 2006 9:39 am    Post subject: Re: Continental differences.. Reply with quote
Tony
Well, something is missing from the US version.
This sentence: "... with several international pin adapters, for use anywhere in the world (when using an adaptor, please make sure it stays cool by placing it in a ventilated area)."
Page 23 of 23
23.091 (03 Sep 25)
