kev1311 Occasional Visitor
Posted: Mon May 15, 2006 1:14 pm Post subject: Heated windscreen |
Does the heated windscreen on a ford have an affect on the quality of reception for an internal GPS reciever?
If so can anyone suggest a remidy to my failing signal and loss of sats? |
peterc10 Frequent Visitor
Posted: Mon May 15, 2006 1:28 pm Post subject: |
Heated screen have little or no effect.
What does have an effect is athermic (heat reflective) windscreens. I understand that latest Sirfstar3 receivers are OK for these though. Otherwise use an external aerial. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Mon May 15, 2006 1:49 pm Post subject: |
Thanks |
Ako Regular Visitor
Posted: Mon May 15, 2006 10:29 pm Post subject: |
It's possible that you may be able to get a better signal if you mount the receiver behind the rearview mirror (if possible) as there is usually a gap in the athermic coating.
Dave _________________ Holux231, XDAII Copilot 6, 1Gb Lexar SD Card |
Posted: Tue May 16, 2006 12:09 am Post subject: |
Ako wrote: | It's possible that you may be able to get a better signal if you mount the receiver behind the rearview mirror (if possible) as there is usually a gap in the athermic coating.
Dave |
I don't think he has an athermic (heat reflecting) screen. He has a heated screen, which many Fords now have. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Tue May 16, 2006 12:14 am Post subject: |
Thanks all so does anyone know why particularly at I should be dropping sats, but if I hang the reciver outside the car I get a strong signal? |
Posted: Tue May 16, 2006 12:17 am Post subject: |
Sorry didn't read what I put it should say:
Thanks all
so does anyone know why particularly at night I should be dropping sats, but if I hang the reciver outside the car window I get a strong signal? |
Posted: Tue May 16, 2006 12:20 am Post subject: |
What about athermic coated glass with integral heater elements? anyone considered this, the heater elements perform a totally different job to the TI coating applied to the windscreen (and it is the later that causes the problem - not the heater elements) - just a though - Mike |
Charlie_Croker Occasional Visitor
Posted: Sun Jun 25, 2006 10:34 pm Post subject: |
I find that the heated front screen in my Focus does interfere with GPS on the Navman 510. If I move the unit down to the bottom Right hand of the screen (where there are no heating elements.) I get a much better signal.
When I had a 310 I could not even get a signal anywhere else. |
